Author Topic: Boiler Exhaust Vent  (Read 1365 times)
Boiler Exhaust Vent
« on: 30 June 2011, 11:54:23 »
What actually goes out of this?  :-/
As its got rather warm past few days, I've considered buying a small air-conditioning unit.
Got to keep nice and cool while on that xbox  ::)
Problem is the vent for air-con, you have to open the window, which kind of makes getting one pointless as all cool air escapes, and its nosier when window is open.
But I noticed I have a huge plastic vent going outside from the boiler (combi) - its exhaust vent.
Would it be possible to combine/add a connection to allow air-con vent to be use this as well, would it be safe?  :-/ :-/
There is enough space above it to add something into it.
Re: Boiler Exhaust Vent
« Reply #1 on: 30 June 2011, 12:10:59 »
They are generaly a balanced flue so the outer part has air going in and the inner CO2.
So no, dont mess with it to!  :y
« Reply #2 on: 30 June 2011, 12:14:09 »
Thanks, did suspect something along those lines.
Back to just using the tower fan then!
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #3 on: 30 June 2011, 13:55:19 »
You can make a mini air con yourself just put some ice in front of the fan. I made one from an old pc fan and a plastic tub with the fan on top pulling the cold air through, you can get more complex by using copper piping and a fish tank pump but mine suited my needs :y
http://www.wonderhowto.com/how-to-make-usb-air-conditioning-162880/
or buy one of these
http://gizmodo.com/181614/usb-air-conditioned-shirt
« Last Edit: 30 June 2011, 13:57:04 by Plomien »
« Reply #4 on: 30 June 2011, 14:03:18 »
or buy one of these
Looks interesting, might need a few to cool my flat though!  :)
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #5 on: 30 June 2011, 15:05:17 »
or buy one of these
That just gives you cool, damp air.  MostAll air-conditioners extract heat and moisture to the outside world.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Lioned
  • South East London
« Reply #6 on: 30 June 2011, 22:46:11 »
If you want to die in the middle of the night this would be a good way to do it.Choose a night when the wind is in a particular direction and it shouldnt take too long.
Seriously though,this is why boiler vents have to be some distance from a window (cant remember how far) but the gas man should be able to tell you.
davethediver
  • Blackburn, Lancs.
« Reply #7 on: 30 June 2011, 22:50:11 »
One and half meters on modern boilers ;)
P.A. Caron de Beaumarchais
Page created in 0.028 seconds with 16 queries.
