Author Topic: Xbox heat sinc repair, alcohol alternative?  (Read 1879 times)
« on: 26 August 2011, 15:24:16 »
Heat sinc paste on the chips on the board have to be cleaned off before the new paste can be applied. Best to use alcohol but I don't have any...I do have  citrus based cleaner
...guessing brake cleaner, or anything petro chemical based is out.
Any suggestions?
Martin_1962
Re: Xbox heat sinc repair, alcohol alternative?
« Reply #1 on: 26 August 2011, 15:57:39 »
Meths
Vodka?
« Reply #2 on: 26 August 2011, 16:00:25 »
Don't have either of those. White spirit is closest but can't see that being good for chips
« Reply #3 on: 26 August 2011, 16:06:58 »
Picked a bit of paste off and tried the citrus cleaner on it. Won't touch it. Doesn't brake it down at all.   :-/
« Reply #4 on: 26 August 2011, 16:37:43 »
I'll have a look for my stuff... It's for removing vehicle sign writing so should be OK and shift it :y :y
« Reply #5 on: 26 August 2011, 16:39:27 »
Sorted. Sticky label remover pen.  :y
Now, htf does this all go back together....  :-/
 ;D
« Reply #6 on: 26 August 2011, 16:40:33 »
Brake cleaner might be worth a try, as it won't leave a residue. Don't just hose the thing down with it, though. Spray a little onto a rag and rub the top of the chip with that. ;)
« Reply #7 on: 26 August 2011, 16:41:23 »
Oh  >:( Too late. Still, it'll smell nice with that citrus cleaner in it. ;D
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #8 on: 26 August 2011, 18:05:59 »
unless it turns out to be a lemon :o ;D
other rides
« Reply #9 on: 26 August 2011, 18:27:07 »
Can't you get a black slimline, they do run much cooler :y
« Reply #10 on: 26 August 2011, 18:31:33 »
I've fixed it. Wifi connected, downloading xbox live update.
« Reply #11 on: 26 August 2011, 18:40:31 »
...could have fixed your old one and saved yourself some curry tokens.  ;)
« Reply #12 on: 26 August 2011, 19:17:05 »
I have some ArctiClean .. which is absolutely no use to you now, really, is it.. Oh well! ;D
« Reply #13 on: 26 August 2011, 19:23:01 »
Better late....     ;D
« Reply #14 on: 26 August 2011, 21:51:58 »
My old one hasn't failed...  ...yet ;)
