Cam Belt Meet - NE Hampshire
Started by Gaffers, 08 December 2010, 10:22:16
QuoteIf anyone coming to the meet has any mfl climate bulbs I would be grateful. :y
They won't be genuine Vx but I might have to pop and get some today because I've got a couple out as well... I've got to remove my stereo for the Tech2 to communicate so may as well change them at the same time ::)
I might have a few of them. Will have a look later.
Thanks LD, I may need an MID lamp as well if you have one. Mine's an MFL. :y
It might be your lucky day ::) ::)
Not sure what I've got but I'll chuck them in the car :y :y
Pantaloons.
I put this off to the last minute but ultimately it looks like I won't be able to make it on Saturday, now, as something has come up that needs taking care of :-/
Do you guys need my 300' extension reel? If so I can drop it off with Kevin/Chris/someone else local tomorrow so it's there on Saturday..
Seth
FAO the 'suspension gurus' ..........
Anyone ever changed anti-roll bar bushes and fancy giving me a hand to do 'em at the meet? :D
There doesn't seem to be easy access to the captive bolts, and I've just found a pair of Poly-bushes that've been buried in my workshop for some time now.
joff
Need to confirm a few part No. before Friday. I have just picked up the parts I need to do the cam cover's and the dealer has given me the below parts which I don't know if they are correct fot an 03 3.2 can anyone help.
1. Rocker gasket X2 GM55351456 are they correct.
2. Seal ring X4 V0012992647 what are they for
They don't seem to have given me the Inlet bridge to head gasket what is the correct number
All the rest I have as per the maintenance guide. I need to know as will have to pick up friday hope they have them.
Thanks for any help. :-? :-/
skyblue
QuotePantaloons.
That is a shame but if required I will throw in my extension lead..  One question  is there an outside tape as mine is desperate for a wash and scrub up ??????
El_Swervo
Hello All,
I would like to come along, Spark plug change and steering idler for me. I have pm'd Guffer with my details, Any tools needed? I have some they may be usefull.
skyblue
QuoteHello All,
Just chuck them in the boot because if you dont you know you will need them ;) ;D
QuoteNeed to confirm a few part No. before Friday. I have just picked up the parts I need to do the cam cover's and the dealer has given me the below parts which I don't know if they are correct fot an 03 3.2 can anyone help.
O rings go round the bolts holding cam covers on, need more than 4 though, 16 in total iirc???
Not sure on cam cover gaskit no.  :-/
Its rare to need to replace inlet gaskits, but if anyting its the inlet manifold to plastic bridge gaskit thats relavant. Unless you know theres an issue with inlet gaskits dont worry about it imo.
Just bring gm cam cover gaskits, o rings and black goo. :y
QuotePantaloons.
Could i pick it up on the way through sat morning?
QuoteFAO the 'suspension gurus' ..........
Fronts? Access from engine bay iirc?
QuotePantaloons.
It may come in handy :-/ :-/
Sorry to hear you can't make it though... Nothing too serious I hope
Checked a few places today and ended up at my local motor factors... He wanted £3.95 Each for climate bulbs :o :o :o I think you can guess my answer :-X :-X :-X
I'll try to swing by a Halfords or something tomorrow and get some unless someone else has a spare 10?
Shackeng
I can pop in to Halfords tomorrow LD, if you can tell me what to get. :y
QuotePantaloons.
Would be useful :y
