Author Topic: Cheapskate?  (Read 3026 times)
Cheapskate?
« on: 11 June 2009, 16:07:58 »
My MV6 had cambelt kit, water pump, aux belt, in early January - 5 months ago. Done about 10k miles on it, I think.
If changing the head gaskets, upon refitting, Would you re-use the rollers and get another 30k out of them?
Just wondering what you personally would do...
« Last Edit: 11 June 2009, 16:08:20 by JamesV6CDX »
Re: Cheapskate?
« Reply #1 on: 11 June 2009, 16:14:50 »
I'd re-use them, and the belt if I could be sure of fitting it the same way round.
Dazzler
  • Haverhill, Suffolk
Re: Cheapskate?
« Reply #2 on: 11 June 2009, 16:21:38 »
What he said^^^^^ ;)
Re: Cheapskate?
« Reply #3 on: 11 June 2009, 16:22:12 »
I happen to have a new belt sat here :)
Although - I did note direction of the old one :y
shammster
  • Essex, UK
Re: Cheapskate?
« Reply #4 on: 11 June 2009, 16:32:12 »
Re-use
after all you know the history.
So many cars to fix, oh well open the beer!
Re: Cheapskate?
« Reply #5 on: 11 June 2009, 17:42:43 »
cant think of a single reason why you would not re use. Apart from the belt direction as said.
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
Re: Cheapskate?
« Reply #6 on: 11 June 2009, 21:46:20 »
im confused about this problem, (DOR) that is, i was always lead to belive that all belts , cam or aux were to be fitted with writing facing outwards :-?
as for renewing i would change it, for what its worth, although it would probilly be fine its always better to be safe than sorry
also in work situation i belive the warrenty would be affeted if anything were to happen
Re: Cheapskate?
« Reply #7 on: 12 June 2009, 07:46:52 »
I'm 18-24 months or so into a cambelt kit, and will have the same decision soon, all though a bit easier....
I think for me, replace the kit, but dont bother with the water pump.
« Last Edit: 12 June 2009, 07:47:10 by jimbob »
Re: Cheapskate?
« Reply #8 on: 12 June 2009, 08:43:06 »
No need to change the belt or ancillaries.
It simply needs setting to the used belt tension
