Vectra B 2.2 wont start
Started by Jimbob, 14 July 2009, 17:01:16
Help
Father in law's vectra wont start
engine turns over, but just wont catch
smell of petrol from repeated tries
battery fine
no fault codes
any ideas?
Ghost
Chip in key or a prob with the Immobiliser?
He who brakes Looses
To old to die young
QuoteChip in key or a prob with the Immobiliser?
no immobiliser is happy.
Head scratcher this one
If you are getting petrol, next obvious check is spark
QuoteIf you are getting petrol, next obvious check is spark
wouldnt know how to check on this bugger
Ghost
easy way take a plug out or use a good Known one put your lead on hold electrode to engine with plieres get someone to turn the key and look for the spark. DO NOT touch plug when engine is turning or running as it will bloody hurt belive me I've done it.
( note to self you Bloody idiot Lol )
To old to die young
cheers CPP unit on this, no leads, so a little more awkward, but will have a play when the rain goes
We have fuel pressure
we have spark
swapped relays where possible
still no joy  :'(
How fast is it turning over?
Is the throttle valve working?
LJay
QuoteHow fast is it turning over?
turns over normally, just wont catch, dont know on the throttle (dbw)
Been there, fallen over it!
Well simplistically, it needs
Air
Fuel,
Spark,
Compression
You have air, you have fuel, and you have spark - compression test it  :y
QuoteCambelt intact?
Chain driven, no chainny noise  :-/
QuoteWell simplistically, it needs
Air
Fuel,
Spark,
Compression
like I know how  ;D ;D ;D
Air
Fuel,
Spark,
Compression
ahh .. but all must occur at the correct time .. does this have the equivalent of our crank sensor ??? ...
Just a thought ..  :)
