hand brake adjustment
Started by Richie London, 21 July 2009, 20:57:03
Richie London
how much is involved adjusting it as my lever is right to the top now and is not holding well unless i am in park. ive forgot to tkae the brake off twice in the last week, too much on mind. i cant seem to find a link for it on maintenance guides.
Ghost
The only thing I can find is in this link.
www.omegaowners.com/forum/YaBB.pl?num=1152564750
If you have a long extension and a deep 13mm socket you might not have to take the heat shield off.
He who brakes Looses
To old to die young
Richie London
cheers, i shall have a look in the morning, if not raining  :y
Richie London
QuoteThe only thing I can find is in this link.
have 3 extension bars so may help  :y
Ghost
#5
Its a bit tight but it does work.
done it yesterday as I renewed all my breaks and disks.
Dont do it like I did and wait till the exhaust is cool. :y
To old to die young
unlucky alf
i would check your handbrake shoes first & adjust them accordingly, then the cable after that :y
Quotei would check your handbrake shoes first & adjust them accordingly, then the cable after that :y
You'll be getting Brownie Points from Mark for being the 1st to state that!  ;D  ;D  ;D  ;D  ;D :y :y
unlucky alf
blimey how did you know i was wearing a brownie uniform :o
;D  ;D  ;D  ;D  ;D
http://www.youtube.com/watch?v=FtSbnql66j8  ;)
Ghost
;D  ;D  ;D  ;D  ;D
;D ;D ;D ;D
To old to die young
Abiton
#11
I used that excellent guide of Mark's yesterday.  Cheers Mark.  :)
I found that a little ratchet spanner thingummy was just the job for the central adjuster.
The real bonus (apart from having a working handbrake, and new pads on the disks), was when I found a generous collection of pea-sized pebbles between the heatshield and the floorpan...
No more horrible clattery rattles when going over anything other than mirror-smooth asphalt!  :y
ians
you should slacken the central cable first (or check its slack already with the handbrake off)
matt-sboro
i found rubble and 2 big rocks in my heat sheild this evening!
