Can the Tech 2 ....
Started by SP_3.2, 10 August 2009, 10:59:21
SP_3.2
Just wondering with the tech 2 is there anyway to set the gearbox  to run on sports mode all the time, i guess you could call it standard setting and then reset the a new  sport mode setting  if you get my point.
thanks
Steve
never seen such an option when I've played.
Can't see it though
a gearbox specialist could maybe do some sort of remap to make it do that, but be a lot cheaper just to press the S button every time.
dont think there would be room for a 'higher performance than S' mode though  :-/
The box is adaptive though - the more you rag it, the closer it gets to sports mode.  Apparently ::)
SP_3.2
QuoteThe box is adaptive though - the more you rag it, the closer it gets to sports mode.  Apparently ::)
Interestingly, I have been experimenting after the EA Meet and having you confirm mine was a little flat.
If I shift manually or put it into sports mode the flat spot disappears :y :y
Brick Tamland
My gearbox if fully customizable, any gear i want when I want it, because its a manual :y
Saving for one! All donations welcome, ask for details.
