MOT failed
Started by tunnie, 07 October 2009, 16:34:50
On a track rod end.
I can't be bothered to do it myself really, going to let the garage do it. But should they be replaced in pairs? I think they keep the tyres flat on the road? Will the tracking / geometry need doing once its been changed? Is it worth replacing them in pairs?
Ljay's failed on one too.
Advised just to replace the one.
about £30 from a factor, and easy to fit.
You will need you geometry doing afterwards though.
good guide in the maint section on doing them  :y
QuoteLjay's failed on one too.
'dangle berries'  >:(
Garage quoted me £30 as well for the part, and £30 to fit.
Seen the guide, but i really can't be bothered to do it  ;D
Besides i think if i take it away, then take it back i will have to pay for another MOT anyway. This way its just 1 MOT and the track rod.
you should have 10 working days for a free retest  :y
you would need to budget for a ball joint splitter as well if you dont have one  :y
The mot, part, tool, and geometry reset came to just under £100 for me.
i am still feeling very lazy  ;D
Quoteyou would need to budget for a ball joint splitter as well if you dont have one  :y
Funnily enough thats what they quoted me all in too. ( although i will take it back to WIM for a reset)
It should only affect the toe setting alignment-wise.
kevin
not worth being WIM'd ?
Quotenot worth being WIM'd ?
I would!
I wouldn't say so if everything else is setup well. Just get them to set the toe back to the setting on the WIM report.
the trouble is this is a fairly basic back street place, they have not noticed twice my hand brake fails to hold on one side.  ;D
I doubt they could get the setting back to WIM standard, it was done around June this year when i had new fronts on, due to bad outside wear.
I think with the miles i am doing, the £60 + fuel is worth another trip to WIM.
Quotethe trouble is this is a fairly basic back street place, they have not noticed twice my hand brake fails to hold on one side.  ;D
I didnt make the trip all the way to WIM, but did get a local place with the same gear to mirror the WIM settings  :y
but you are a LOT closer than I am  :y
I reckon its about £20 quid in petrol return....
Given the price of a new set of tyres if left to wear prematurely ..... thats a bargain !!! even with the WIM charges added !!
