Author Topic: MOT in the morning...  (Read 2868 times)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« on: 03 May 2010, 18:25:14 »
...starting to get that horrible feeling in the pit of my stomach.... only had one first time past in the last ten years or so, putting the odds against me.  :(
I know it's not going to fail on tyres, bodywork or exhaust, but potential areas are handbrake efficiency and front lower wishbone bushes...  :o
Lambda was close last year, but the exhaust was in poor shape (shiny new stainless job now), so think there was some air getting in there. No warning lamps or codes, so a quick Italian tune up on the way should help along!!! :)
Wish me luck  :D
« Last Edit: 03 May 2010, 18:28:22 by rockhampton »
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
MickAP
  • South Derbyshire
Re: MOT in the morning...
« Reply #1 on: 03 May 2010, 18:28:19 »
Good luck :y
There's not been may failures lately on here, so keep the faith :y
Mick ;)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #2 on: 03 May 2010, 18:29:28 »
Good luck :y
Mick ;)
Cheers, Mick - I do tend to be an optomist, so a handbrake adjustment or something like that I can live with  :y
« Reply #3 on: 03 May 2010, 20:02:57 »
Good luck mate, although i'm sure you won't need it  :y
Squealey
  • Donington, Lincs
« Reply #4 on: 03 May 2010, 22:37:42 »
Best of luck, just make sure its clean, ALL the lights work, the washers are hitting the screen and the wipers are clearing it efficiently.
Sounds silly and im probably teaching you how to suck eggs but when I was a mechanic our MOT tester told me that if things as simple as that were not sorted beforehand then he tended to look that little bit harder for other things that may be wrong.
Wayne
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5 on: 03 May 2010, 23:26:15 »
Good luck pal, and let us know how you get on  :y
MickAP
  • South Derbyshire
« Reply #6 on: 04 May 2010, 12:25:34 »
Wayne
Apart from doing all the necessary work, mainly rear brakes/handbrake clean adjust. I cleaned it inside and out, it looked really good pre MOT.
Passed of course :y
Yes I reckon if you take something in that looks dodgy they will try harder to find something amiss.
Mick ;)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #7 on: 04 May 2010, 12:37:02 »
Well, it looks like the OOF streak of good luck (Pob Lwc in these parts) continues.... IT PASSED  :D :D :D :D
Small advisory on front disc wear, but they should be fine until the next pad change.
They said the handbrake was actually very efficient, the lever seems to travel a lot, but is well within tolerance. :y
The car was clean inside and out, so that probably helped along..... 13 months MOT now, Happy Bunny!!! :) :)
    • E250 Est / Elroq
« Reply #8 on: 04 May 2010, 12:38:46 »
good result  :y
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #9 on: 04 May 2010, 14:56:53 »
Nice one mate   :y
« Reply #10 on: 04 May 2010, 17:07:12 »
I told ya the good luck wouldn't be needed! ::) ;D ;D ;D :y
MickAP
  • South Derbyshire
« Reply #11 on: 04 May 2010, 19:09:04 »
Yet another pass :y :y :y
Mick ;)
