Author Topic: LPG Tank size. HELP!  (Read 3576 times)
« on: 13 May 2010, 21:09:50 »
Really torn as to what to do, LPG tank wise.
Even if I raise the boot floor in the estate by 7cm, which is hell of a lot - I will only get a 45/50litre usable capacity with a toriodal tank - which is rubbish on a thirsty V6 (whoops, let that one slip).
The only reason I own an Estate, is to cart two medium size dogs about.
Much of my driving in the summer months will be long distance - some of which will be european this year, and I really do need a decent range. I also need to bear in mind, that I NEED to carry a spare tyre at all times. I've been stranded with a shreded tyre in remote locations before - never again thanks!) - so I think a toroidal tank is out of the question.
I am, therefore, giving serious consideration to mounting a cylinder tank in the boot of an Estate - I know it's not the norm, but, I think for my purposes, it may well best suit?
What are your opinions?
And also - say I mounted a 400mm width tank, would you consider there to still be a fair bit of boot space?
Undecided here  :-/
« Last Edit: 13 May 2010, 21:10:25 by JamesV6CDX »
Re: LPG Tank size. HELP!
« Reply #1 on: 13 May 2010, 21:12:08 »
alternative is to fit torpedo tank length wise, rather than across the back. On either passenger or drivers side. Gives practically to put seats flat, dogs will still have good space
    • E250 Est / Elroq
« Reply #2 on: 13 May 2010, 21:13:07 »
question is....whats the minimum space the dogs need, and then whats left?
    • E250 Est / Elroq
« Reply #3 on: 13 May 2010, 21:13:39 »
hard to mount though like that arent they?  turn to a missile in a crash...
« Reply #4 on: 13 May 2010, 21:15:56 »
Strapped down should be fine, no worse than if it was set across. Strapped down my tank is not going anywhere.
Should be ok to mount, filler feed
« Reply #5 on: 13 May 2010, 21:17:36 »
Not sure what LPGA COP states about mounting it length ways - personally, I'm really unsure it's a good idea.... doesn't fill me with comfort  :-/
« Reply #6 on: 13 May 2010, 21:23:28 »
With the strapped type (that we have), thats a BIG no-no.
James - seeing as you only keep your cars 5 minutes, that may affect resale?
« Reply #7 on: 13 May 2010, 21:24:49 »
Possibly... although to be honest, Omegas are generally worth so little, it's almost not worth worrying about..  may as well have something that's more useful to me ? :-/
    • E250 Est / Elroq
« Reply #8 on: 13 May 2010, 21:25:44 »
Ye cannae change the laws of physics  ;D ;D ;D
    • 530D M Sport, 330i Coupe
« Reply #9 on: 13 May 2010, 21:26:45 »
Don't forget that if you plan to use the car abroad you won't be able to use the chunnel with LPG.
« Reply #10 on: 13 May 2010, 21:28:13 »
Ferry every time  :y
« Reply #11 on: 13 May 2010, 21:52:48 »
Ferry every time  :y
Yup, train is over priced, and you can stretch legs / get breakie on ferry  :)
« Reply #12 on: 13 May 2010, 22:35:20 »
Ferry every time  :y
Ferry is too bloody slow....
« Reply #13 on: 13 May 2010, 23:16:06 »
Ferry every time  :y
And the entire ship covered in puke in a storm.  :-/
« Reply #14 on: 14 May 2010, 02:34:01 »
James, I have a 400mm tank in the moot of my saloon and there's still a fair bit of space... You can always build a box to stand over it (once the LPGA cert is done) to enable stacking on top :y
Tunnie, the straps are only going to hold it the way it's meant to be mounted... Lengthways there is very little strength! LPGA regs don't actually specify which way it has to be mounted but I wouldn't do it again. I had noe lengthways in my Rangie but, unless it's a large vehicle hitting you up the rear end, it wouldn't be in the crumple zone :y
