air con question...for a vectra ;-)
Started by Dan Hope, 27 June 2010, 13:56:40
Dan Hope
Hi
sorry, bit naughty, but you guys have helped so much with my omega questions you just might know the answer to this with my new (to me) Vectra C...
When I test drove it, the a/c was ice cold and from all vents. The day after I bought it i had vauxhall service it (hopefully not connected to this problem). Just used the air con for the first time today and from the top far right vent, the air was cold, the next vent to my left wasn't as cold, the one next to that was warmer still and the one on the far left was even warmer.
If i shut off the far right vent, it forced the cold air to the next vent and so on.
Any clues what this might be? VX did do an engine coolant change, would that affect the heating system at all? Heat comes out evenly from all vents as far as I can tell
Cheers
Dan
Has it got his & hers temperature controls like the Omega?
If it has are they both set to the same temperature?
If yes and yes then has the linkage fallen off one of the temperature control flaps?
Dan Hope
Hi, nope, its just got the plain old aircon. that was tomorrows job, check the flap arm things behind the dash, be just my luck to get a vectra that does the same thing my omega did haha
[movedhere] Omega General Help [move by] Jimbob.
