Author Topic: Anyone ever changed a reluctor ring on a Rover?  (Read 4507 times)
Re: Anyone ever changed a reluctor ring on a Rover?
« Reply #15 on: 01 August 2010, 13:59:20 »
You nont need to remove the hub, just the lower balljoint so you can swing the hub assembly forward enough to get the joint out.
« Reply #16 on: 01 August 2010, 19:06:31 »
Crap crap crap crap double crap.
Rounded off the torx bolt that holds ABS sensor on  >:(
« Reply #17 on: 01 August 2010, 19:07:43 »
Not sure I understand? as in turn it full lock, then a little bit more (tracking off track rod as well)?
« Reply #18 on: 01 August 2010, 19:14:20 »
Detach lower (wishbone) ball joint and you cna swing the hub out whilst still attached to the strutt....this will give enough slack to get the cv joint out of the hub.
Simples
« Reply #19 on: 01 August 2010, 19:26:01 »
Simples
Have you done that on a Rover 25, as not convinced there is movement in the strut  :-/
I'll give it a go once I've located my flippin splitter, and bought some split pins (presumably they shouldn't be reused?
« Reply #20 on: 01 August 2010, 19:50:13 »
Simples
Undo the large nut in the end of the CV joint and then the bottom ball joint and track rod end, that will allow the hub to be pulled out enough to clear the end of the CV joint. Be careful not to pull the opposite end of the drive shaft out of the gearbox as you will end up with a large pool of gearbox oil on your drive ::)
« Reply #21 on: 01 August 2010, 19:52:43 »
Simples
The one that you see in middle of brake disc once the wheel is off?
hotel21
  • The Kingdom of Fife
« Reply #22 on: 01 August 2010, 19:54:42 »
Simples
Yup, would think thats whats meant.   :y
« Reply #23 on: 01 August 2010, 19:59:00 »
Simples
Yep... Be aware that it may well be a Left Handed thread too :y
You can probably get away without splitting the TR End by turning the wheel to full lock after removing the Bottom BJ ;)
« Last Edit: 01 August 2010, 19:59:54 by Lazydocker »
« Reply #24 on: 01 August 2010, 20:05:03 »
Great, that will save me from having to do anything with that stupid torx bolt that I've knacked.
« Reply #25 on: 01 August 2010, 20:16:46 »
Simples
Thats the chappie, it retightens to 180nm ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #26 on: 02 August 2010, 10:39:41 »
rovers use a  normal rh thread on the hub nut,as others have said just undo bottom balljoint and swing hub out to gain neccesary clearance. joint is a knock off type so no hidden circlip to grapple with
other rides
Page created in 0.057 seconds with 14 queries.
