MOT tomorrow ,,,,,,,,,,,,,,
Started by I_want_an_Omega, 03 August 2010, 21:25:26
I_want_an_Omega
wish me luck guys ,,,,,,,,,,,,,,,
spud1990
wanna take it to my local garage they pass anything lol good luck  :y :y :y :y
Hope everything goes well for you Robert 8-) :y :y
Varche
Fingers crossed. Always an anxious day. :y
I_want_an_Omega
Should be ok, hope the oil leaking (smoke) from the cam covers dosn't colour the testers view.
First test of the day so hopefully he didn't get out of bed the wrong side  ::)
Good luck Rob, take the tester one of your sausage baps ;)
I_want_an_Omega
QuoteGood luck Rob, take the tester one of your sausage baps ;)
You liked those didn't you .............  :y
Have you bought any ?
Good luck LR, will it need any luck? What do you think? Pass or fail?
I_want_an_Omega
Hi,
Its a fail, but I'm not in the least bit bothered as it was only a headlight adjustment and probably my fault as I'd swapped it for a "better one" it and probably screwed the adjuster in the process.
The tester said the car was in excellent condition and it was obvious that it had a lot of recent work done. The emissions readings were also very low.
So, I'll get the headlight sorted & I'll be an even happier bunny.
TTFN
QuoteHi,
Its a fail,  ..... it was only a headlight adjustment  .....
'screwed the adjuster' as in broke it? Or screwed the adjuster to much/not enough? 'My' MOT tester would have correctly adjusted it as he tested the car.  :-?
I_want_an_Omega
He tried to adjust it but wasn't able to .......
QuoteHe tried to adjust it but wasn't able to .......
Oh!  :( Goosed adjuster?  :-/
I_want_an_Omega
dunno - will take a look later & see whats what.
I guess there is a separate aujuster from the ones that the levelling motors operate?
Am not getting any error messages from the xenon system - although did when I forgot to plug the motor in.
Must do some work now  :(
replacement metal adjusters available from the sticky in parts for sale (or see maint guide)
