Rear bushes on MV6
Started by TheBoy, 16 August 2010, 12:03:23
Quite happy to sort your at Newent Jimbob, it will take about 1-2 hours.
QuoteQuite happy to sort your at Newent Jimbob, it will take about 1-2 hours.
Cheers, much appreciated, ill hang on from the geometry till then  :y
ive got a set of the febi ones ready to go on  :y
What are the current recommend droplinks - think the MV6 has eaten a set of those as well. Still, 167k, can't complain...
QuoteFebi Bilstein iirc  :y
For droplinks? Where from?
hotel21
I got the full pretzel wishbones, droplinks and rear doughnuts from Allgerman.  Will rake out the cost but not too outrageous...
hotel21
QuoteI got the full pretzel wishbones, droplinks and rear doughnuts from Allgerman.  Will rake out the cost but not too outrageous...
Was £200 delivered for the lot, all vacuum packaged as Lemfoder.
Gaffers
QuoteI have some to stick on too, back end is all over the place.  Job for this week I think, first though I have to build myself a puller.
in case it helps, i used a £15 job from halfords, it works differantly from the special tool described in the book of lies in as much as it clips on the bush edge and pushes through the centre to pull the bush out, meaning the centre bolt needs fitting loosely for it to push on.
book of lies shows the special tool iirc, if you whan to make the puller, may aswell make the correct one?
or bring it over here if you prefer?
That's a kind offer, how are you fixed for this week?
By the time the ale is flowing, who cares where we collapse.  JohnyCBoy often doesn't make it as far as his tent ;D ;D ;D
He only makes it anywhere because gravity takes over. ;D
weekend? either day, probably saturday if possible? week days are out due to shift work, baaaah.
i like thier donuts, the void holes where semi filled in on TB's. Not sure if it was deliberate or a moulding issue but wondered about replacing my genuines with them, may be a little firmer?
mine were ebay
mine were ebay
http://cgi.ebay.co.uk/Stabilizer-Link-LH-RH-Fr-Vauxhall-Carlton-Omega-Senator-/130419215275?pt=UK_CarsParts_Vehicles_CarParts_SM
although brand is listed as various  :-/
Gaffers
This weekend I am away fishing in and around Poole, looking to grab the end of the mackerell season.  Weekend after that looks promising.
or bring it over here if you prefeor?
on hols that weekend from week tomorrow, mon, tues, or weds evening.?
