insignia washer jets
Started by Andy B, 30 August 2010, 21:34:29
I've seen mention of these ......... but senility means I can't now find it. :-[   They are on eBay for around £5 for the pair clicky  How does that compare with the dealer's price?
very close to dealer price, iirc < £2 each.
edit, £1.95 each, plus vat...
I paid £1.66 +vat each  and still need to fit the little gits  ;D
Quotevery close to dealer price, iirc < £2 each.
Thanks Jimbob.
I'll call at a dealers on my way home from work tomorrow & see what they have in stock  :y  :y
davethediver
Whats the reason for fitting them?
"It is not necessary to understand things in order to argue about them."
P.A. Caron de Beaumarchais
QuoteWhats the reason for fitting them?
Fan shaped spray pattern which wets the screen better and results in lower screen wash useage
Are they a straightforward swap over :question
davethediver
QuoteAre they a straightforward swap over :question
Was just about to ask that rob :)
:P ;D
Not to bad, drivers side is hardest.
You have to swap the heaters over to (not essential but the insignia does not have washer heaters)
davethediver
QuoteNot to bad, drivers side is hardest.
Does my car have these its only a four pot CD ;D ;D
Watched H21 do his at The Lakes so i've bought some for both my Elites, hoping to get them done at Newent if I get a chance.
Trouble with HID's is you still use about 3 litres every night time trip when there's spray from the road!!!
Weve got loads of photos....intended doing a how2
May try and finish at newent, or here
The trickiest bit iirc was removing the heater from the old to glue into the new ones.
QuoteWeve got loads of photos....intended doing a how2
H21 used a hacksaw blade and sliced down the originals to extract the blue heating element.  :y
gstylebaby
#14
Will have to a have a look at this when your done jimbob...but thinking about mine and they are in the bonnent so would have to get the holes filled so mite wait till i make my mind up on when i'm geting the car sprayed. :-/
