Pages: [1] 2 3  All   Go Down
Author Topic: coil pack bolts  (Read 8073 times)
majesticlarge
  • Gravesend Kent
coil pack bolts
« on: 25 October 2010, 17:03:57 »
Hi all
When changing the plugs in my 2.2 i found that the 2 long bolts that hold down the coil pack rattled around, i pulled them out popped the coil pack out and found the was no thread for the bolts to screw down into just 2 large holes, is there meant to be something in them ? this is the first time i have looked under here so never noticed it before.
Washing a car, is like making love to a beautiful woman.  caress the bodywork. Breathe softly and gently. And give every inch of it your loving attention. And make sure you've got a nice wet sponge.
majesticlarge
  • Gravesend Kent
Re: coil pack bolts
« Reply #1 on: 25 October 2010, 17:04:57 »
just noticed i put this in wrong area :D Doh
Re: coil pack bolts
« Reply #2 on: 25 October 2010, 17:07:33 »
yes there should be a thread, you can just about see it in my cam cover guide:
majesticlarge
  • Gravesend Kent
Re: coil pack bolts
« Reply #3 on: 25 October 2010, 17:11:55 »
mine hasn't got those so the coil pack has been rattling round for well since before i got the car.. wonder if i can devcon a nut over the hole that fits the thread?
Re: coil pack bolts
« Reply #4 on: 25 October 2010, 17:19:21 »
Does it have a 2.0l head on it?
Re: coil pack bolts
« Reply #5 on: 25 October 2010, 17:20:03 »
sounds like someone has stripped the thread?  :o  :-/
With the coil in the plug, its fairly secure, but not ideal. Maybe worth tapping a new thread?
majesticlarge
  • Gravesend Kent
Re: coil pack bolts
« Reply #6 on: 25 October 2010, 17:23:06 »
can't tap a new thread as the holes are way to big, I was told it had some work done to the head before i got the car so could it be like said a 2.0 ltr rocker cover ?
Re: coil pack bolts
« Reply #7 on: 25 October 2010, 17:27:42 »
Yup, sounds like its got a 2.0 top head on it, with 2.0 it was coil pack on the back, not coil per plug.
The bolts are only very lightly nipped up anyway, being a boding student i would just leave it  ;D
majesticlarge
  • Gravesend Kent
Re: coil pack bolts
« Reply #8 on: 25 October 2010, 17:48:30 »
are you saying the whole head is from a 2 ltr or just the cover ?
Re: coil pack bolts
« Reply #9 on: 25 October 2010, 17:50:38 »
Whole head, the bolts for coil pack go into the head. The cam cover is just plastic...
« Last Edit: 25 October 2010, 17:50:56 by tunnie »
majesticlarge
  • Gravesend Kent
Re: coil pack bolts
« Reply #10 on: 25 October 2010, 17:52:29 »
I would never have thought a 2ltr head could go on a 2.2ltr lump, does this mean my car is a 2lr now not 2.2 ?
Re: coil pack bolts
« Reply #11 on: 25 October 2010, 18:03:36 »
I've never had a proper look under the bonnet of a 2.0 or 2.2 car. If it did have a 2.0 head on it, then what would these stripped holes have been for if a 2.0 uses a separate DIS pack. ....unless someone drilled clearance holes instead of tapping holes in the replacement 2.0 head.  :-/
majesticlarge
  • Gravesend Kent
Re: coil pack bolts
« Reply #12 on: 25 October 2010, 18:06:51 »
Don't know maybe i should put a pic of the holes on here ?
Re: coil pack bolts
« Reply #13 on: 25 October 2010, 18:13:55 »
The head cannot affect the displacement of the engine...
majesticlarge
  • Gravesend Kent
Re: coil pack bolts
« Reply #14 on: 25 October 2010, 18:38:47 »
thats a shame might have been cheaper to insure  ;D ;D ;D
Pages: [1] 2 3  All   Go Up
