ATF change, gearbox seems smoother!
Started by geoffr70, 23 November 2010, 20:06:09
geoffr70
Hello, a few hundred miles ago I changed the ATF in the AR35 on my 3.0 Elite. Prior to this it didn't seem to be jerky or unsmooth or anything untoward apart from a clonk noise very very rarely and only when it was cold.
After the change it seems much better, alot smoother, it seems to change up earlier from a cold start and not hang onto gears. The changes are barely noticeable, and when you pull away it does it seamlessly! Yeah some of it could be in the mind, but I'm happy with that!
One more job down!
TC and BnQ Trade holder.
millwall
im going to change mine soon  i have no problems with the auto box  but my car has done 92k so it wont hurt to do it
geoffr70
I thought I had no problems until I changed the fluid now it's lovely!
Mine had 115k on the clock when I changed ATF, it hadn't been done upto then.
Automatics rule
millwall
good news  might try and do mine a bit sooner
geoffr70
What engine/box have you got? I made a little guide for this job, it's still in the test section atm. It's quite straightforward though
millwall
mines a facelift 2.5 v6  i think it has the ar25  box but not sure
millwall
just read your guide and very helpful   if i have the ar25 box is it basically the same to do
geoffr70
Quotejust read your guide and very helpful   if i have the ar25 box is it basically the same to do
From what I have heard on OOF the 2.5 has the ar25. I would've thought it'd be the same if not v similar. The filter is the same. I imagine the casing and sumps etc will be the same only the innards might be slightly different due to cost etc.
Yes, boxes indentical from a fluid change point of view  :y
(not forgotten your guides, actually hope to sit down to night and sort them out)
Omega_Dan
Will be having mine done before christmas. Good to hear your results!
djac
Will be getting mine done in the New Year - 130k miles on the original ATF (as far as I know).  :o
millwall
QuoteYes, boxes indentical from a fluid change point of view  :y
thanks for confirming that jimbob   will definately give mine a change   lot easier having a guide to refer to :y
geoffr70
cool Jimbob, thanks :y
Get the tech2 updates for your box, and it will be even smoother. :y
geoffr70
QuoteGet the tech2 updates for your box, and it will be even smoother. :y
I will try, but I don't think there is anyone near me, and I'm not paying stupid dealers stupid dealer rates when I'd rather give it someone on OOF!
