Author Topic: How dose Climate control work below 4c  (Read 2239 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 08 December 2010, 13:10:33 »
I think the AC cuts out a 4c and under. So with the temp set at 24c how dose the car keep that set temp without the AC working alongside it.
Thanks
Steve.   :y
hoofing it
Re: How dose Climate control work below 4c
« Reply #1 on: 08 December 2010, 13:19:54 »
If I mind right you have to press the windscreen demist button the fan comes on full pelt and the air-con cuts in.
also make sure the air recycle button is on and the A appears in the centre of fit
« Last Edit: 08 December 2010, 13:20:37 by hoof »
« Reply #2 on: 08 December 2010, 15:43:22 »
The same as normal as the incoming air will be 4degC or less anyway.
It just heats the air up
« Reply #3 on: 08 December 2010, 18:11:34 »
As the Master says, doesn't need to chill it, as the incoming air is cooler than A/C chilled air anyway :y
SP_3.2
  • Leicester
« Reply #4 on: 08 December 2010, 21:48:27 »
Cool thanks all  :y :y
    • E250 Est / Elroq
« Reply #5 on: 09 December 2010, 07:42:58 »
Good Good  :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #6 on: 10 December 2010, 21:38:41 »
Is the air-con switch-off feature common to all Omegas with CC, then? Or is this just a farcelift thing?
I've just never heard it! Always put it on ECO during winter, to save wasting the air-con.
« Reply #7 on: 10 December 2010, 23:11:09 »
It's common to air con on cars! It doesn't run when  there's a chance of the condensate produced by the air conditioning freezing in the system & buggering it up.
Not 'wasting' your a/c? You're doing it more harm than good. A/C systems need to be run on a regular basis to help stop seals from drying out.  ;)
« Reply #8 on: 11 December 2010, 10:39:26 »
...and ime, misting windows is still more common ESP getting into a cold car  :-?
