Author Topic: head gasket gubbins  (Read 1798 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
head gasket gubbins
« on: 01 July 2011, 22:30:04 »
Where is the best place to get gaskets and bolts for cyl head?  Obviously valve stem seals etc from dealer....
Martin_1962
Re: head gasket gubbins
« Reply #1 on: 02 July 2011, 00:30:46 »
Ebay is actually OK for parts
I got them all seperately
    • E250 Est / Elroq
« Reply #2 on: 02 July 2011, 08:02:14 »
Trechii is the seller you want for head gaskets and bolts
ring him, dont just get one of the packs with more in it than you want.
Gaffers
« Reply #3 on: 02 July 2011, 12:37:54 »
I've just bought his HG and bolts off his ebay site - I'll get the manfold gasket and the oil stem seals from vx.  I may just get some new camshaft seals on standby just in case.  What else do you reckon I'll need?
I'm off to pick up some s/h heads in a bit.  The idea being that I can get them ready with the new manifolds fitted and the head given the smallest skim you can get and check the core plugs etc so I can swap them over in one weekend rather than take mine off and then realise I have issues (I suspect a coolant leak from the core plug Pass side but I cannot verify  :( )
I had to take the gearbox oil pump to a fabrication place to get it skimmed, looks like it'll take nearly 2 weeks with his backlog though.  Once I get the heads swapped the gearbox I am refurbing will get swapped.  Inbetween the bodywork is getting sorted, I have found the Holts 68L is a very good match for my paint colour, and some new wishbones are going on tomorrow morning (hangover permitting)
