Author Topic: Brakes next...  (Read 3768 times)
Brakes next...
« on: 24 August 2011, 22:25:00 »
Thinking along the lines of...
Front.
EBC dimpled discs. Try trade club pads on them, find their crap and fit oe  ::)
Rear.
EBC discs, but the rears aren't dimpled, no biggy. Pads same as front.
Because I believe EBC disc don't rust as badly, is this correct?
don't particularly rate EBC pads. Not tried them but they don't seem to do the right grade. Green too soft, red don't work cold on the motorway...?
Goodridge braided hoses all round to replace the rubber lines that must be spongy by now.
DOT 5.1 fluid(the stuff that mixes with DOT4 with no issues.)
Obviously the question is, will GM pads work on EBC discs...  :-/
Re: Brakes next...
« Reply #1 on: 24 August 2011, 22:29:42 »
My gut reaction is that its the caliper that causes the odd wear on the inner side of the disc.  Can't prove it, as GM discs are:
a) adequate, so I haven't experiemnted beyond really cheap shite discs
b) cheap ;D
Re: Brakes next...
« Reply #2 on: 24 August 2011, 22:33:32 »
Seen it(inner edge rust line) on other Marques as well...
serek
  • huntingdon
    • 3.2 mv6
Re: Brakes next...
« Reply #3 on: 24 August 2011, 22:33:47 »
Front.
Rear.
where you can buy them from ??
« Last Edit: 24 August 2011, 22:34:14 by serek »
Re: Brakes next...
« Reply #4 on: 24 August 2011, 22:35:04 »
Front.
Rear.
Hoses. Buy parts by had best price last I looked.
« Last Edit: 24 August 2011, 22:35:52 by chrisgixer »
2woody
  • Northumberland
Re: Brakes next...
« Reply #5 on: 25 August 2011, 08:50:06 »
want me to make some hoses for you ?
Re: Brakes next...
« Reply #6 on: 25 August 2011, 09:36:57 »
The EBC discs I have on the MR2 don't rust anywhere near as fast as the OE discs (though there are 'better' discs out there for rusting - they usually come pre-coated with paint, though), and so far they haven't warped/exploded/killed me.
In the past I've tried Green & Red Stuff on other cars - running Yellow on the MR2 at the moment and the bite from cold is perfect and it's impossible to make them fade.. I was wary initially (given previous heart stopping experiences with Red Stuff!) but they've clearly done some major reformulations..
The Omega is much heavier, of course, but they certainly work well on the MR2 - you wouldn't know they were a 'track only' pad.
Re: Brakes next...
« Reply #7 on: 25 August 2011, 20:31:11 »
All on floating caliper setups?
Only ever seen it on my Vauxhalls (but then the Fords have been company vehicles, and all my others have been Rover)
Re: Brakes next...
« Reply #8 on: 25 August 2011, 22:57:18 »
Panda, fiesta, focus, Bmw....probably all all single pot floating caliper set ups, although didn't note it tbh.  :-/
I put it down to the inboard face being more exposed to damp and splashing under the car...  :-/.  The tin guard doesn't extend to the bottom of the disc, so some is exposed...???  :-/
Re: Brakes next...
« Reply #9 on: 25 August 2011, 23:00:52 »
Its well known fat people need good brakes  :y
Re: Brakes next...
« Reply #10 on: 25 August 2011, 23:06:30 »
;D Now remind me, where did I tell you to stick your stands again...? Big head!   ;D
 :P
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Brakes next...
« Reply #11 on: 25 August 2011, 23:09:42 »
 :P
Just you wait.  I was a 32" waist in uni :y
Re: Brakes next...
« Reply #12 on: 25 August 2011, 23:12:33 »
 :P
Yeah, been there. Got the tee shirt (it's a little tight now) ::).
Re: Brakes next...
« Reply #13 on: 25 August 2011, 23:18:06 »
 :P
...I remember the day I went "over square" ....  :(
Re: Brakes next...
« Reply #14 on: 26 August 2011, 08:17:16 »
 :P
Up until my mid 20s, I was 28" and 9.5st.
I hate to say 'I told you so', but I have told the useless student several times over the years that all of a sudden the weight would go on  ::)
