jimbo125
Was going to work on the miggy today but her in doors wanted the decking jet blasted, so what she wants she gets. The tinnitus is quiet enough without her nagging ;D ;D ;D
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
EMD
Put the air con on and still ice cold from last year which is a first for any omega ive owned  :)
Omegatitis
ted_one
Found the cause of a nasty nearside knock on one of the MV6's.....  droplink had got loose :o nipped it up and all's quiet again.
pauls
As stated in another thread i had a new stainless back box fitted :y
joff
Quote from: nitro on 06 May 2016, 16:03:31
Will have to check mine on the estate as I have the same, drop links and rear track control are the only things I have not checked :y
Stargazer57N
Replaced Diff oil, cleaned front brakes, copper greased  the brake pipes and a little undersealing done.
Quote from: VXL V6 on 05 May 2016, 00:02:23
Can sort you some out (also have a faulty door solenoid as well) so can drop some off when next passing.
Cheers Mr VXL :y
What some switches to refurb the motor?   And you've reminded me, I need to change one in the Bullet that's gone a bit lazy  :-[
Quote from: EMD on 06 May 2016, 15:42:35
I was using TBE last week, as she was away (and can't drive anyway), because the A/C works.
Looking at the history I have, it's never been regassed in 13yrs :o
Quote from: TheBoy on 08 May 2016, 09:35:41
Superior Facelift see ;) :D
Quote from: NewbieDocker on 08 May 2016, 09:55:12
The SB's first failure was probably about 12yrs in, needing a regas. Sadly, a couple of years ago when Mrs TB refused to drive he inferior FL, the compressor let go quite badly, and I've never bothered to resolve it, given that I think its now on borrowed time  :'(
Shackeng
Pumped out the ATF in the TD box, and refilled, took 5 litres, so at least its refreshed until I get round to dropping the sumps. 8)
annihilator
converting my mum's garden shed to my omega parts store shed  ;D
John.
Fixed someone else's and broken the trolley  >:(
Steve B
Quote from: Shackeng on 08 May 2016, 13:25:25
Did you syphon it out  :-\
Migv6 le Frog Fan
Washed, polished, cleaned interior of my 2.5 to get it ready to sell. I will miss the old girl after approx. 5 years of ownership and a lot of effort to get it (mostly) up to the spec I wanted.
