Not driven either of them all week yet, weather to nice not to bike it in  8)
2boxerdogs
Gave the Merc a good run out today, it really can fly !!
treated Big blue to an oil and filter change and replacement bumper loom.
Started it for the first time in 3 months and she fired up first time!  :y
biggriffin
Had code 303, so thought best sort it.
Changed plugs x6, changed oil n filter, refitted splitter, cleaned breathers, checked my£28 shockers  :y thought let's change the fuel filter, after wat seemed like an age, using the correct fuel clip pliers, it's off, found a new 1, fitted it, started it up, whoosh fuel all over the floor, bloody clip hadn't seated, two different clips later, seems fine, so had a bath in Tesco 99' :-X.
Hoof'land storeman.
jimbo125
Connected up exhausts to manifolds, SAI pipes back on, heat shields in place, coolant intake pipe back on and oil cooler pipes put on. Coolant pipe onto thermostat and bastard bolt finally located >:(
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
Finally changed the oil on TBE - its not often that I get the chance, as she's often out at the weekend, but as she is not allowed to drive currently, it meant it was all mine :)
Oh, and the oil really wasn't pretty  :-[
joff
Inlet manifold off to check for coolant leak and looks like HBV has failed again >:(
Quote from: joff on 24 April 2016, 10:21:35
At least that's easy and cheap.
Dan282
2nd autobox service in a week. This time changed no 2-3 soloniod which was the cause of my poor gearchange.
Quote from: TheBoy on 24 April 2016, 09:48:53
Really must do mine... It looks very bad by my standards and, worse still, I actually can't remember the last change!  :-[
Can't be too bad as it's still got a nice golden colour to it but.....
EMD
Finally stopped the water leak from the sensor on the rad  ;)
Omegatitis
tigers_gonads
Emptied the back of the car of the saleable contents of my old caravan which me and the lad dismantled in a lay bye in 3 hours last Monday before scrapping what was left  :y
I parked on the weigh bridge for a minute on the way out.
With fat bastard me in the driving seat, skinny git mini me in the passenger seat and crammed with the internals and windows of the van, the weight gauge read 2180 kg  :o :o
I drove home rather sedately  ;) ;)
Swapped the projects bumper for a far better one that was lurking in the loft. Crash bar is immaculate and all looking rust free around the front end except for some minor surface rust which I scraped off, painted rust convertor on then went over all the unseen parts with under seal. Also remove the SL pump which will make a bit more space for the LPG ECU.....
