Fitted new front springs and shocks to the mum bus plus new discs and pads to get rid of the Apec shite that was fitted and had failed in 20k miles! (all last Saturday pm)
mandula
Quote from: mandula on 03 June 2016, 07:05:57
Quote from: TheBoy on 02 June 2016, 18:08:26
Quote from: mandula on 02 June 2016, 18:02:05
Could not find any replacement part for rear subframe rear bushings, so made a patent from old bushing casing and from modified new dif to subframe bushings. Still need to grind and paint and then test..
Anything is better than teared originals, I guess.. Will some day make better ones, these are just for quick repair and testing.
Link to pic: https://www.dropbox.com/s/q0p4c0osagdwi7g/2016-06-02%2019.18.45.jpg?dl=0
Report back :y
Well, it's not perfect, but will do for awhile.
Bushings are bit too soft, no much support when cornering (can feel rear to move little, but does not effect handling too much).
Also clearances are too small, subframe fitting points knock a little when accelerating.
But resonance that could be felt with old bushing while slowing down in certain speed gear on, wanished.
Next I'm gonna make some CAD drawings for new casing for bushing with right clearances to subframe and try to find PU-bush to fit to casing.
Can somebody help me to get dimensions of the rear subframe rear end bushings? I didn't have any tools to measure them yesterday when I had a change to do that.
So if someone has one of those in hand, could you measure just general dimensions, spacing between mounting holes to chassis and how deep bushing sleeve surface is from bushing casing (or offset from mounting hole centre).
Professional pic of wanted dimensions: https://www.dropbox.com/s/59pd9pc3nm6n0nd/2016-06-03%2014.07.54.jpg?dl=0
Thanks!
Fitted a set of front drop links, which cured a niggly knock.  :y
Quote from: Marks DTM Calib on 03 June 2016, 10:33:41
In between fitting and commissioning a new kitchen ??? ;)
baggedestate
got the rear air ride finally all sorted good, fitted rear leather seats and travel assistant and finished wrapping the last two pillers
Tick Tock
Made use of the good weather and continued with the back-end refurb......  after spending far too may hours cleaning surface rust, prepping and painting, managed to get the rear bumper crash bar back on the car.
Looking a bit better now.
Omega 2.5 V6 Facelift Estate.
ffcgary1
Refitted the temp gauge wire which became dislodged after moving the cable tray on the passengerside bank to tighten the loose spark plugs last weekend.
Then found the servo to plenum pipe broken at the small vac pipe t peice, replacement inbound as i type.
(thanks sjc ) :y
Gary
Jaguar XJ6
neil74
If I can remove the wheelarch screws on my estate then ill probably have much worse greeting me when the rear bumper is finally off. and if it's anything like the sills and chassis legs  :'( and if I cant hold off the rust for as long as possible then i'm afraid it's bye bye car.
Drove it to Caernarfon on Saturday, drove it back today.
EML came on. CBA to get Tech2 on it, though suppose I ought to before its trip tomorrow..
Migv6 le Frog Fan
Ive been touching up little stone chips & scratches.New eibach rear springs arrived. New old GM wishbones cleaned up, painted, bushes etc. removed ready to fit all the new parts to. Must remember to order the parts tomorrow.
Quote from: neil74 on 05 June 2016, 22:52:40
This is what I found when I moved the bumper to repair some accident damage/previous poor repairs:
As always, it was worse than it looked: the entire flange was barely attached and both inner and outer panels needed new metal.
Which is easy enough, this took about 30minutes:
Quote from: TheBoy on 06 June 2016, 19:45:46
TBE? You've been driving too gently :-X ::)
mandula
#12627
My master-plan for replacing original rear subframe rear bushings.
I will use Powerflex 99-112 95 SHa bushings, needs to be shortened a bit. They are on the way to me, hope I can assemble these this weekend and fit.
This edge attach towards subframe
This edge goes towards gas tank
May be that I dont weld that crossmember above where subframe attaches to avoid it to touch subframe or cut it a bit from center. Will see..
annihilator
#12628
currently got the elite sorn'd and whilst waiting for the irmscher kit and a few other things to be sorted had put the battery on charge for a few days.then in a ceremony which I liken to that in the Kelly's Heroes film in which they start up the tiger tanks for 15 mins to keep them sorted I fired the v6 up only to be greeted with this.
luckily it seems one of the easier of the many p.a.s. pipes in the engine bay to replace.(it's the rubber one without the heat protection that's gone)
John.
jimbo125
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
