Migv6 le Frog Fan
New door check strap bushes. Installed the GM rear wishbone bushes in the wishbones I have refurbed, so they are now ready to fit onto the car. I might post up a pic of them as they look very sexy.  :-* :)
Tick Tock
Omega 2.5 V6 Facelift Estate.
Migv6 le Frog Fan
#12827
I tease no more.  :D
GM wishbones cleaned, repainted, balljoints & bushes removed. New balljoints, new powerflex polybushes and new GM rear bushes.
My omega will have a front end like a Lotus Elise..........................almost.  ;D
New pair of Sachs rear springs in the background also to be fitted soon.
Also the front mudflaps which I took off to clean them properly - very very sad.  :-[
Fitted ETS exhaust on Project II last night.  :y
Lagondanet
NSF link rod changed. Knocking is gone.  :y
Adjusted the handbrake on the BMW and washed the Omega.  :y
Took the 3.2 to work, as that has super cold air con.  8)
T.m.f
Been busy at work,moved jobs nearly 3 months ago and moved in with the wife to be,so just had time to start working on the disco,so far its been lifted,and a/t's fitted,had to change rad last week as that had started to leak,also fitted a tube winch bumper ready for the winch,but the new project is rebuild current 300tdi engine,so sump is off,both manifolds are off and ready to remove head over the next few evenings,then order everything to rebuild the engine.
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
2boxerdogs
Used it for work today (Merc) filled it on the way home & then cleaned the screen & front end of all the insects killed en route home.Now in the garage for the next 26 days holidays!!
GastronomicKleptomaniac
Peered at them, since I have no time to do anything other than work, eat and sleep at the moment...
Took the Westfield to work as that doesn't need air con. ::)
Quote from: Kevin Wood on 21 July 2016, 00:41:03
Saw a yellow one on the M25 this morning (OK, might have been a Caterham) - someone else clearly had the same idea.
And with the warm weather there's no chance of skating on ice and bending it :-X ::)
Washed it. First time since April  :-X
Apparently it is metallic and not matt :-[
pauls
Had the a/c checked and regassed. Cold now :y
