Quote from: Sir Tigger on 27 June 2016, 20:25:13
New air con condenser.   :y
I now have a coolant leak!  :(
Reseated a couple of hoses, but have discovered that my leak comes from the lower ATF pipe on the rad.  I must have dislodged the seating when I undid the banjo bolt.  :(  Trouble is I can't get a spanner on it to nip it up, so I guess I'll have to undo the banjo again.   ::)
Migv6 le Frog Fan
Ordered the A/C condenser that I thought I ordered last Saturday.   :-[ ;D
Quote from: Migv6 on 28 June 2016, 14:45:28
Age, Migs, age ;D
Migv6 le Frog Fan
your not wrong.  :( :'( ;D
Nearer 60 than 50 now.  :'( :'(
frostbite
Topped up the diff. Sounded like it was slipping,  although it's like there were pebbles in the diff than oil on a fast standing start
e46 325i se - 1.8vvti avensis liftback
Quote from: frostbite on 28 June 2016, 23:22:21
Slipping how? It only has gears in it ???
frostbite
Well more like a long grumble when you floor it from a stand still. Put in about 700ml then it seeped out,  we'll see how it is tomorrow
GastronomicKleptomaniac
Turned one of the 190s round in the yard. As I 'm too lazy to move everything it ended up a little like this...
Also got the breadvan home - MrsGK is starting the recommisioning* this evening...
*stripping it down and finding its thirty times worse than expected and having a paddy
Migv6 le Frog Fan
Fitted the other handbrake cable on sons Punto that I didn't get time to fit yesterday. His EML light has been on lately, but apparently its gone off after the engine was serviced, which is nice.  :)
Then removed bagpipes, coolant rad and A/C condenser from the Omega ready to fit the new condenser, hopefully tomorrow.
Gave the lower engine bay a bit of a clean up while I was down there.  :)
Ran out of coolant. Fortunately, there was a Hellfrauds about 400yrds from where I was working...   ...so I felt the need to disturb Mr DTM's morning and query what was needed.
joff
Full service with all filters on the wife's X type and new disc's and pads. New MoT too. That's her off my back for a bit :y
pauls
Relised i still have the old problem with the rev counter  >:( so gave it a good hidding on the way home from work tonight.
78bex
When into my trusted tyre depot  with the front wheel off my Fazer in the boot. Got a nice fresh Bridgestone fitted by the one bloke in there who knows how to fettle bike tyres correctly & respect the rims Nice  :)
Got talking about the Omega & the mot is looming. The fronts are getting quite low now &  the rears are only slightly better. I had 4 Kuomo tyres fitted by this mob 4 years ago.
I was happy with this mid-range tyre, it was quiet, with good grip in the wet.
A nice bloke runs this place & offered me 4 X Kuomo HS51 W rated &  fitted for under £300.
With the afternoon off, I let the boys get on wth it, free coffee & telly to boot.
gbh
I went to a scrapyard and managed to get a Brink towbar for the est off a Omega est and a few other bits.If anyone is interested it had a good load cover was in silver Z147 it was a cd estate 2.6.
Migv6 le Frog Fan
Fitted new A/C condenser and refitted all the stuff that had to come off to get the old one out. Ordered a new Bosch 246 coil pack.
