Quote from: VXL V6 on 09 August 2016, 07:36:03
More rust grinding, converting, painting and undersealing on Project 2  :'(
On the upside, the nearside sill is pretty much rust free with just a surface patch which ground back to solid metal  :y
I know the offside isn't going to be the same story though  :-[
From personal experience I always find the near sides worse than the off sides.
Fixed the thermo fuse in the mum bus aircon compressor, surprisingly easy and no need to de-gas or remove the pump
Quote from: Migv6 on 09 August 2016, 08:16:15
Intended to fit wishbones but spent much of the day trying to remove o/s/f locking nut. No chance, done up windy gun tight, key knackered by windy gun no doubt. Tried hammering on smaller socket etc. but it wont budge.
Going to buy one of those reverse threaded socket things today.If that doesn't work , a new set of cobalt drill bits, it is.
I have the full set(of six, I think) of reverse threaded sockets, and most of the time they still don't fit. When they do the success rate is poor. If the locking nuts have a rotating collar, you will need to remove it before trying the socket. A sharp chisel and some applied Anglo-Saxon are required.
Personally, I wouldn't bother buying the sockets but would go straight to grinding the head off the bolt with a die-grinder and carbide burr, or welding a socket to it.
EMD
Cut some rust out of the classic car , surprisingly solid stuff to patch to  :P
Omegatitis
Migv6 le Frog Fan
Quote from: Nick W on 09 August 2016, 08:34:22
Knocked the locking ring off yesterday using an old screwdriver as a chisel. It broke off surprisingly easily. Don't have access to welding gear, so will probably try grinding it off or drilling it out.  :y
Quote from: Marks DTM Calib on 09 August 2016, 08:26:30
Unfortunately I can push a screwdriver through the sill on the offside by the jacking point, have a new 'pattern' sill to weld on in readiness though.  :y
Quote from: Migv6 on 09 August 2016, 11:43:28
It's a tedious job, but it's even worse when you do it after various other failed methods.
neil74
Changed the headlamp level sensor and the transmission mounting bracket that I cracked when I forgot to remove the axle stand after the oil change.
Picked it up...
Fun begins in the morning...
Steve B
Quote from: Doctor Gollum on 10 August 2016, 20:14:39
Picked it up...
You bought a BMW from Tesco  :-X
Quote from: BIGtime on 10 August 2016, 20:23:17
Picked it up...
As a 525, it's clearly from the Value range ;D
jimbo125
Friends VW Golf miss firing like a pig and running rich, found fault breather pipe on rocker cover split in two. New one from flea bay £15 hate to think how much from FAG
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
