Watched Mrs TB drive into the back of the Battlebus.  I knew I shouldn't have fetched the bloody thing and let in stay on the drive.
biggriffin
Quote from: TheBoy on 22 August 2016, 19:15:39
Whoops.
Hoof'land storeman.
Discovered two things about the BMW that I didn't know yesterday...
Firstly it appears not to have a coolant level sensor, and secondly it requires a new radiator due to a crack at the top hose spigot >:(
Still, new replacement is £45 delivered, so not all bad news :D
Diamond Black Geezer
Watched a mate drill a hole in my rear breather box.  :o Worry not, it is a spare, is off the car, and I asked him to do it  :y
He has rather skillfully tapped the hole, and we now have a machine screw holding the plate on. Intention is, of course to clean it out, then replace my current breather box, while the plenum is off for my major service this weekend.
Looking at the state of this one, which is still clogged after a day soaking in various de-greasers, I can see more elbow grease required!
neil74
Took mine for it's MOT and it failed on the 3 items I new it would namely the front nearside wishbone (bush) offside rear shock absorber and the bloody airbag light from when I changed the nearside windows after the local chavs smashed them.
Good stuff, at least no nasty surprises  :)
neil74
I'm glad there were no nasty surprises. because if it had needed a lot more doing to it then chances are the poor old thing would be making it's final journey to the scrapyard. but my faith in the car has been restored to a point and now i'll see about getting the aircon working and some other little jobs doing before we have another ice age.
Oops!!!
Repaired the alternator (new regulator) and refitted it, then drove it :y
Quote from: NewbieDocker on 23 August 2016, 20:06:13
Job jobbed then hopefully  :y
Quote from: Doctor Gollum on 23 August 2016, 20:09:32
Yep... Should have taken pictures of the old and new and the problem was obvious :-X ::)
Quote from: NewbieDocker on 23 August 2016, 20:11:41
Like this you mean...
Quote from: Doctor Gollum on 23 August 2016, 20:13:46
That'll never fit an Omega :-X ::)
No... The brushes were worn to half their length :y
joff
