annihilator
elite came back after having a new cambelt kit,water pump,poly belt and the damaged sump pan replaced and most importantly another 12 months mot. :)
John.
Quote from: NewbieDocker on 19 August 2016, 09:29:55
Sadly, work commitments, and the shenanigans with one of bro's shops have prevented any prepping before presenting it.
Spill the beans
[/quote]
What, that I've been busy at work, and that I've spent all my spare time over at bro's who's shop fit "hasn't gone well"
:P
Quote from: Doctor Gollum on 19 August 2016, 22:30:20
Never got either Omega to misbehave significantly :-\
"Not trying hard enough"
EMD
Well windscreen trim has come loose again  >:( Shall call them out for the 4th time  :(
Omegatitis
Shackeng
Put the gearbox back in the TD with a new thrust washer, new filter and fresh fluid. Drives nicely on the test run. I'll check the level again in a week or so. Next job is to see if I can swap the gear change shaft from my AR25 into the new Senny AR35. But it can wait. :y
Quote from: Shackeng on 21 August 2016, 18:04:59
Nice one, Chris. Are you the go-to fella for gearbox problems now?  ;D
Shackeng
Quote from: STEMO on 21 August 2016, 18:08:42
No No No! I'm too old for this sort of work, but I can't resist a challenge, which ends up by me regretting it. :-[ :y
Well....you've persevered and done a great job.  :y
biggriffin
Went to work and washed it, saved me £6.00. :D
Hoof'land storeman.
Migv6 le Frog Fan
Repainted one of my alloys at work last night. Refitted it today and took another one off to refurb at work tonight.
Also took one of the rear track rods off the car, which I have brought to work to see if a I can free it off.
biggriffin
Quote from: Migv6 on 21 August 2016, 19:41:27
Clamp in vise and heat it up to red hot, un screw, then dump in bucket of waste oil, re-assemble, with lots of copper-slip.
Hoof'land storeman.
Migv6 le Frog Fan
Clamped it very tight in vice, heated as hot as I could with a heat gun, got a big pair of stilsons on the end, it unscrewed very nicely. This was the outer end. Did the same with the inner end, pushed hard on the stilsons, it rounded the "nut" section in the centre of the rod and chewed up the visible threads while it was at it. Its officially shagged. Need a new pair.  :'(
