Quote from: Migv6 on 18 May 2017, 17:40:17
Quote from: STEMO on 18 May 2017, 13:40:54
Quote from: Migv6 on 18 May 2017, 11:27:50
Ive had plenty of "excitement" in my life up to now. I'm now trying hard to slip slowly and quietly into decrepitude.
Well mind you don't need to go into a care home.  ;D
I have informed those concerned that I will top myself when that day arrives, and I wasn't joking.  ;)
Trouble is, you tend to lose the ability to top yourself...unless you're going to piss yourself to death.  ;D
Failed to get the Focus up the track to where we're staying last night, ran out of power.
Let it roll all the way to bottom again, and gave it all it had.
It probably averages 1 in 3 for about 250m, with bottom 50m or so being concrete, rest completely unmade - so no momentum just means wheelspin
Not that the bastid thing has any power anyway
Quote from: TheBoy on 19 May 2017, 12:52:25
Tried it backwards, so the correct wheels are driven? :D
Quote from: Kevin Wood on 19 May 2017, 12:53:45
Did that on first day getting up the short less than 10m driveway, about 1 in 2 slope. No clutch stinks like a hire car clutch ::)
ronnyd
As DG said a couple of days ago, what could possibly go wrong TB. :D ;D
Admired my shiny new front shock absorbers that I didn't put on and freed up the seized offside track rod, ready for alignment and new tyres.  :)
Fitted a new to me ABS sensor to the nearside front wheel, but the ABS light came back on.  :(
peter the butcher
Treated the old girl to a good wash and mini valet.... did I do it myself? no, just sat in a chair with a cuppa, money well spent, saved me on my own doing it for an hour probably, and they did a very good job too  :y
Zirfeld
Playing around with my new sand blaster. Variations in jet diameter, blasting material....learning by doing.
At last it works really good.
Later this afternoon I tested to remove the rear suspension bolts. One after the other. They all are free, nothing rusted. So removal of the rear suspension will be no problem.
97 Caravan should be great.
Rolf
I am not forced to drive an old Omega. I simply like it.
Disabled the rain sensing wipers in the VW via VAGCOM, to try normal variable setting instead. Live data check and all is well with DPF and other codes.
Dumped the Focus, mostly unscathed, and the mundano, complete with battle scars
Quick cuppa when you get back later?
Quote from: Doctor Gollum on 21 May 2017, 10:42:27
It's the whole tribe, so will pass this time :)
No worries  :y Safe flight... Just landed there btw ;)
Quote from: Doctor Gollum on 21 May 2017, 10:50:21
You on holibobs again? :o
