Keith ABS
Took the Monza out for the first time last night after its winter dash removal for heater motor and matrix replacemant. Time I got home after 30 miles, small water leak inside car and fuel leak from around pump area. Supposed to be at a show in Wallingford on Sunday so here's hopeing
Keith ABS
Quote from: Kevin Wood on 04 May 2017, 20:10:01
Quote from: RumpelStiltSkin on 04 May 2017, 19:57:39
Put over £80 of go-go juice crude in it :(. Been a bloody long time since I've spent that much at the petrol station  :(
FTFY. ;)
No arguments here, KW
Bought and fitted a new electricity container for the Battlebus.   The charger's inbuilt test 'dangle berries' function was claiming it only had 28% capacity left on the old one.
Hopefully all the electricity won't keep leaking out of the new one :)
biggriffin
Quote from: TheBoy on 02 May 2017, 18:12:41
Waited for the scrapyard lorry not to turn up  >:(
You did remove the front pipes( downpipes)?
Hoof'land storeman.
neil74
Sounds like me waiting in for Nigel from Nottingham on sunday after he said he was interested in my 3.2 estate and was coming to fetch it after saying numerous times he wanted it.. it goes without saying it's still here. and the part that really gets me is all he had to say was it was too far to come and it wasn't worth his time but no not even a call to say he couldn't make it.
Fraggles Rock
Quote from: neil74 on 05 May 2017, 19:30:33
Give Steve at Omegaspareparts a shout assuming that it's a definite breaker... He's a hop, skip and jump along the M4 ;)
YZ250
Done nothing to the car but did put the scrambler back together. Took it for a test run, I'd forgotten what a blast it is. Power band is either on or off and it won't forgive you for being kind to it.   ;D
2boxerdogs
Washed & polished the Merc & fitted new wheel centre caps.
Quote from: biggriffin on 05 May 2017, 18:45:57
Nope, CBA
Quote from: TheBoy on 06 May 2017, 15:19:42
Broke the Battlebus again
Fixed it.  MAF had decided it had had enough. It was a cheap egay special nasty one, so I guess I was lucky to get a couple of years out of it.
Original now back on.
Quote from: TheBoy on 06 May 2017, 18:15:19
I think I may have a DTI one somewhere... i'll have to have a look.
Fraggles Rock
Quote from: VXL V6 on 06 May 2017, 22:24:19
If not, I do :y
I think the original MAF is fine, it was only swapped while chasing other issues I had at the time.
Migv6 le Frog Fan
Washed it yesterday. Hoovered it this morning. Might give myself a treat and drive it to work later.  :)
