Quote from: Lazydocker on 24 June 2017, 09:02:00
Quote from: TheBoy on 24 June 2017, 08:47:07
Quote from: Doctor Gollum on 22 June 2017, 22:24:54
Fussy tester... Fibreglass it with a gallon of underseal and call it done ;)
Or take it to a certain establishment for beardy types and Hornby lovers just outside Nottingham, enjoy a chip butty and a brew, and watch the master at work ;D
Which I have a strong suspicion may be the case ;D
I know it, you know it, my mum's dog knows it
Quote from: TheBoy on 24 June 2017, 09:23:51
3 Guesses where we are going this morning ;)
Zirfeld
Today I replaced wintergarden`s xenons by the original candlelight  :'(. Normally the Caravan has the xenons, but that is not allowed on the 97 model for Tuev, because it don`t have headlight cleaners and automatic leveling.
Monday it is Caravan`s birthday. 20 years old  8) and I am working for his next 20 years...
Rolf
I am not forced to drive an old Omega. I simply like it.
frostbite
vacuumed out the engine oil cos im a lazy arse and saying that I spilt the the new oil  into the plug valley so had to mop it up
e46 325i se - 1.8vvti avensis liftback
TD
Quote from: Zirfeld on 24 June 2017, 17:33:23
Rolf
You can get away with that in the UK the MOT testers don't seem to notice.....  :y
Zirfeld
Happy UK Omega owners!
Of course I will replace the candle lights after Tuev in August or September as soon as possible. When Autumn comes, I need the xenons again.
paul l
Got down and dirty inside the rear wheel arches. While its been so dry I thought it`d be good to remove the arch guards,  clean off all the muck and wax oil it to death. Please to report no nasty surprises  :y
Failed to replace the 2 centre exhaust sections on TBE. Why are even the easiest jobs sometimes a complete PITA ;D
neil74
Started my wreck up and drove it down some dual carriageway and then brought it back and parked it on the driveway.
frostbite
Whilst cleaning my TB I found that my maf to tb elbow had a split  >:(
Promply dug out the spare one and swapped it over  :y
And filled the washer bottle with some cheap blue stuff
Fitted a 2nd hand door catch mechanism to the O/S rear door on the Purple Fiesta.
It doesn't beep at me now, the lights and message have gone and I didn't break any more plastic clips!  :y
Gave up drilling out exhaust bolts around midday, need better drills.
So serviced the lawnmower instead.
Chazza12
not much just cleaned all the doors and boot rubbers.  sprayed water wax in breathers to clean any muck that has got in the rubber breathers out, should help give a better seal nas they softer now. :)
Walk past it twice with the dog...
Went to fit the custom made HEL brake hoses (to the kit) only to find that I'd somehow ordered them several cm too short (to the tune of ~10cm). Arse.
There's another £60 down the big hole in the ground I call a kit car! Might as well have bought a boat at this point...
