Author Topic: So what have you done to your car today?  (Read 8403801 times)
0 Members and 58 Guests are viewing this topic.
« Reply #15375 on: 02 December 2017, 17:47:16 »
being left instructions to clean the kitchen
When did you grow tits? That's a pink job!
I'm sure our Lincoln Lord will concur.
Suffice to say, Mum is 5'2" and 70 this week ;)
Again, I can predict Opti's advice, you need to get a young wench in.
That leads to much worse problems
Like broken laptops...  ;D
2boxerdogs
« Reply #15376 on: 03 December 2017, 21:36:24 »
Bought a set of polished alloys for the wifes Subaru Forester.
« Reply #15377 on: 03 December 2017, 21:47:54 »
Well...
Got the breathers and throttle cleaned, plug wells drained, plugs changed, camcover gasket replaced, thermostat changed, hbv and associated plumbing changed - speed fit connectors were leaking, new hoses appear to have sorted it, coolant changed and oil and filter changed.
Had enough for today, so cambelt/waterpump can wait.  :-X
« Reply #15378 on: 03 December 2017, 23:09:04 »
Changed the radiator. Hopefully there'll be a brief respite from the weekly coolant top-ups until something else springs a leak. ::)
« Reply #15379 on: 04 December 2017, 09:55:11 »
Sprayed the clutch master cylinder bracket.
I really intended to do more.. until the dog had a slight incident (he went for another dog :-[ :-[ ) which rather shook me (he'll be on the lead from now on if there's another dog even in the distance, and possibly always regardless). Ho hum.
    • E250 Est / Elroq
« Reply #15380 on: 04 December 2017, 15:34:14 »
Discovered a weeping heater matrix. Bugger.
« Reply #15381 on: 04 December 2017, 16:18:35 »
On the 3.2 I assume?
    • E250 Est / Elroq
« Reply #15382 on: 04 December 2017, 16:38:01 »
Yup. Looks great fun to change :-(
« Reply #15383 on: 04 December 2017, 16:39:16 »
From what I've seen dash is completely out  :'(
Any warning signs? Where can you actually see the leak?
    • E250 Est / Elroq
« Reply #15384 on: 04 December 2017, 16:41:48 »
We have a cheats method which involves some cutting.
Diagnosis is smell and getting fingers to where it lives which is moist. Underside of floor mats also damp where it's drawing the moisture out the carpet.
« Reply #15385 on: 04 December 2017, 17:05:18 »
Oh, dear. Perhaps I should count my blessings that mine was only the radator (and before that, the HBV, and before that, the LPG vapouriser, and before that, the water pump).  :(
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #15386 on: 04 December 2017, 17:22:40 »
Removed and dismantled n/s headlight, and fitted a new headlight adjuster. All reassembled now but ran out of light so will refit it to the car and attempt adjustment tomorrow.
« Reply #15387 on: 04 December 2017, 18:53:23 »
I had intended to go out and swap the cars over, but suffered CBA.  So I guess I'll just have to use Mrs TB's TBE tomorrow. Oh well :D
« Reply #15388 on: 04 December 2017, 19:22:32 »
This is the tip of the iceberg... If the carpet is damp, there's about a litre of coolant already in the sound proofing ;)
Migv6 le Frog Fan
« Reply #15389 on: 05 December 2017, 11:17:01 »
Headlight and its trim refitted this morning. All ready to take swmbo out this afternoon to begin the Christmas shopping ritual  :'( :(
My arthritis may well start to give me a lot of trouble quite early in proceedings today. If this happens, I will unfortunately have to go and sit in the car and listen to the radio.  ::)
