Quote from: Elite Pete on 26 February 2012, 11:47:33
Replaced a set of wishbones with poly front bushes and Vauxhall rear bushes :)
Got a pair ready as well  :)
The Red Baron
StuntS
Quote from: VXL V6 on 26 February 2012, 13:03:37
Any chance of some daylight pics?  :)
I'll do some tomorrow for you....... ;)
noel
give her a good polish with auto glym high definition wax (beautiful) ;D.Its amazing how big a car the omega is  :y
adey2
finally had to change the rear self leveling shocker on my car after it popped, been leaking fluid since i had but got moneys worth out of it, lot of persuasion needed to remove bottom bush out suspension though
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
General bodywork tidy up with rust treatment and primer .
Tyre pressure check.
Car looks boggin ...must clean  ::)
Anyone got a bucket load of POLAR-SEA-BLUE  ???
Guinney1971
really must sort out the rusty bits on Morticia, and t-cut the bonnet....... got some post Meguiars stuff coming in the post, so will put that to good use this week weather permitting  :)
Claire
Claire & Phill
Renault Grand Scenic 'Maxim' 1.9dCi 120
Zippy2012
Quote from: VXL V6 on 26 February 2012, 15:52:01
How much did it cost to do the bushes?? as ive got to sort mine out asap!
£40 for the front poly bushes and £30 for the Vauxhall rear bushes ;)
Zippy2012
Quote from: Elite Pete on 27 February 2012, 13:09:25
where from???
ive just fitted a full pollybush kit into a disco 1, 8 bushes took me 2hours just to get the bushes out, had to burn 4 of them out as a 16ton fly press wouldnt budge them a mm..!!!
i hope the vauxhall ones are easyer!!
Quote from: Zippy2012 on 27 February 2012, 13:22:56
where from???
Sorry I thought you meant how much were the bushes. I drilled the rubber section of the front bushes then hacksawed the metal outer ring so I could remove it and the rears were pressed out and new Vauxhall bushes pressed in on a mates press. The wishbones were new though
Zippy2012
Quote from: Elite Pete on 27 February 2012, 13:26:09
where from???
i did ask how much, just i forgot to also ask & where can you get them from??
adey2
ive finally got stereo working its sat nav on a ncdc1300, new cd lens check, new drive unit check, still buggered, new disk into life it goes, grrrrrrr should of done other way round and saved some money
Quote from: StuntS on 26 February 2012, 00:01:08
replaced my worn climate buttons with some decent = buttons and fitted a new dvd head unit....
sorry for the poor quality pics.
Good fix on the climate :y
Think the stereo looks chavvy, and I reckon too low to be useful in Omega. But each to their own :)
Quote from: adey2 on 26 February 2012, 19:56:04
Hope you did both....
