cableguy
Well, another day at the car today.
Changed the cam sensor, so far so good  :y
Gave her an oil and filter change  8)
That should be it for a while now, apart from rear electric windows, seat looms to make my leather heated, rear grab handle lights and find an aerial that fits properly as some on has put a spoiler on so i cant have a proper whip bit.  :-[
Omega 2.2 GLS Estate With added MID and Leather.
Code reader & EML reset for local members.
doz
paul.lovejoy
put some new wipers on the ones Dan used 3.99 ebay excellent value and work very well :y
Removed S/L suspension off the DTi (Thanks to Loo Knee for answering the daft and obvious question midway through!) and replaced with some Bilstein B4's. Suppose I may as well remove the pump when it's next up in the air as well....
Took off old knackered drop links , boy were they bad  ::) just like the track rod ends  :-X
New ones on , what a treat  ;)
Shimmy
Took off my contiwintercontacts.
Put on my Rainsport 2's.
Budget tyres, false economy.
Changed the oil & filter on project CDX estate.Started to remove the wheels intending to take the tyres off and put them on the CDX wheels I have, then refit them. Cant find the locking key anywhere.I believe I may have left it attached to one of the wheel nuts when I went to the MOT station the other day. :'(
Quote from: Albs on 10 March 2012, 18:32:33
Hammer & sharp cold chisel jobbie ;D :D
CaptainMorgan
Bought a new glovebox lid to replace the broken one. Took less than a day of owning the car to be irritated by it being permanently open  ;D
tgm147
Kicked the front left tyre out of frustration only to find another new rattle.  ::)
Omega_Dan
I replaced the number plate bulb and fixed the glove box handle as one of the pins broke.
Took the Jaaaag up to see a friend.. fell off the little lip between his grass and his driveway, over on the side of my foot, twisted my ankle, went down like a sack of spuds and now it's absolute agony; I'm using a dining chair like a zimmer frame.
Add me to the list of forum cripples!  :'(
Quote from: cableguy on 10 March 2012, 13:41:21
...find an aerial that fits properly as some on has put a spoiler on so i cant have a proper whip bit.  :-[
Search for "Prodrive aerial base" and you'll find the answer ;) A little angled ball that sorts the problem :y
Quote from: aaronjb on 10 March 2012, 22:11:49
Ok.... Cripple! :P :P ::) ::) ;D ;D
Quote from: Lazydocker on 10 March 2012, 22:12:41
I knew I was barking up the wrong tree looking for sympathy here  :P :P ;D
