marrus69
after breaking transfer pipe, new one came yesterday.all fitted back today it was easy to put back.test run temp running at 90 happy days,anything else goes wrong now its going.
Zippy2012
Today im in the process of fitting a replacement 200 series discovery front axle
inc full polybush kit new +2" shocks & springs & +2" braded brake hoses
then ive gota sort a brake squeek thats driving me mad on my omega when driving...
its squeeking constantly when i brake it stops couple of corners starts again!!! Arghhh & also 1st time brake they hardly work but if i tap the peddle & brake again pulls up strong so maybe a seized calliper or very warped disc coz its like ive just fitted new pads & piston needs pushing out a little bit to work.... its driving me mad!!!!
Darth Loo-knee
Fitted some cam covers for a guy from Scotland, as his local garage messed them up. Used 3 litres of oil bringing it down :o
So you can imagine the smoke as the oil is trying to burn off :D
Quote from: Darth Loo-knee on 23 February 2012, 13:06:03
:o...must have been fun driving that esp in traffic jams  :'(  (...."smoking!")   :P
yesterday actually... Dug out the paperwork and realised it's due MOT on the 1st March ::)
Better get some fuel in it and the battery charged ::)
Track rod ends on a Megane and discs and pads on an MX5. Nice easy day :)
Guinney1971
planning on taking Morticia to see the Lithuanians in a bit to get her washed, then gonna try some paint renovator on the bonnet as its the only faded paintwork on the car.
Claire
Claire & Phill
Renault Grand Scenic 'Maxim' 1.9dCi 120
The Red Baron
well, after having major coolant leaks from the lpg 3.0l elite i decided to investigate. ive never seen such a bodge with the cooling pipes for the lpg side tbh. a T piece on the feed to the hbv & a T piece on the return to the hbv. thats six potential leak points, & yes they where. So, removed T pieces & piped evaporator up to coolant bridge outlet & return to hbv inlet. now how simple is that. lmfao.....plenumn off, inlet manifold off plus all the gas gubbins, just to get at the coolant bridge pipes, what a fookin job that was. all up & running again now though. just the front bumper & backing bar with a non leaking water bottle to fit now. cooor what a day. :D
I need to do a similar tidy up job on the front end of my LPG installation in the not too distant future.Coolant pipes/wiring/feed pipes to injector blocks/relocate ECU......been avoiding it for a while tbh,but it needs doing. ::)
Guinney1971
Quote from: TheBoy on 23 February 2012, 19:07:45
Put around £130 of fuel in it  :'(
:o  :o  :o  :o  :o  :o  :o
thats more then 5 fill ups with lpg for me!   :o
Claire & Phill
Wing fitted, and while the side skirt and bumper was off...  ;)
Quote from: chrisgixer on 23 February 2012, 20:17:57
That means we'll get more snow next week :-X ::) ;D
Quote from: Guinney1971 on 23 February 2012, 19:45:28
Guess you have a small tank, or don't like running low ;D
I did manage 317m from a tank yesterday, my new record (80l tank)
Quote from: Lazydocker on 23 February 2012, 20:52:48
Nah, start of the second ice age knowing my luck!
