Author Topic: So what have you done to your car today?  (Read 8383023 times)
0 Members and 93 Guests are viewing this topic.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #22635 on: 13 August 2021, 23:54:00 »
But younger than me 😶🤐 :y
Laying a rubber road.
countrywoman
  • worcestershire
    • skoda yeti
« Reply #22636 on: 14 August 2021, 08:53:52 »
Spent yesterday moding the front suspension tower on the Austin due to narrowing front suspension the lardy Omega front callipers fouled on full lock and full drop . Best bit was all the callipers are free and all the nipples and unions came out fine, not bad for bits that have been standing for nearly 20 years!
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #22637 on: 14 August 2021, 16:58:28 »
Bordering on the miraculous !
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #22638 on: 14 August 2021, 20:27:32 »
Took the V70 for MoT.It failed on a brake flexi hose and there were a couple of advisories for headlamps-the silvering on the reflectors gets trashed due to the DRL's also being the dipped beam headlamp bulb-New brake flexi hose bought[£7.79p]and fitted brakes bled up and a pass issued. :y
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #22639 on: 15 August 2021, 13:18:21 »
Got the Range Rover ready for its MOT & service on Tuesday.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #22640 on: 15 August 2021, 13:28:50 »
Congratulations on the MOT pass  :)
now get the Omega sorted  ;D
BazaJT
« Reply #22641 on: 21 August 2021, 10:09:49 »
Went to lock up yesterday, all 4 wheels off and I'm getting brake fluid at all bleed nipples no sign of air bubbles yet brake pedal still pushes straight to the floor >:(
Migv6 le Frog Fan
« Reply #22642 on: 21 August 2021, 11:18:07 »
Master cylinder ?
  • Auckland
    • Mazda MPV
« Reply #22643 on: 21 August 2021, 11:33:21 »
Master cylinder ?
It is the most plausible answer.
40 years ago you would have paid 2s & 6d for a packet of new master cylinder seals and had it fixed by lunchtime.
2 weeks later you would discover that the master cylinder was scored and the new seals were shot as well so you would do the job again but get the cylinder reamed first to remove the scoring.
BazaJT
« Reply #22644 on: 21 August 2021, 18:07:09 »
Master cylinder was my thoughts.It seems no seal kits are available[Big Red certainly don't have them] Were all Omega master cylinders the same or were there different types? The one on mine seems to say Lucas on it but it's awkward to see as it's partly under the reservoir.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #22645 on: 21 August 2021, 18:40:10 »
Master cylinder was my thoughts. It seems no seal kits are available[Big Red certainly don't have them] Were all Omega master cylinders the same or were there different types? The one on mine seems to say Lucas on it but it's awkward to see as it's partly under the reservoir.
A quick Google turned up several, both seals and new pistons LINK .
 I'm not keen on rebuilding this  sort of thing, and would only order rebuild parts after dismantling the suspect unit. That means immobilising the car for several days, and increasing the work.
Especially hard to justify when a similar search turns up new cylinders for £75, LINK
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #22646 on: 21 August 2021, 19:03:21 »
Yet another crank but no start issue on my rusty builder's van  Omega  ::)
replaced the duel filter ,still no joy.
battery started to die which wasn't helping matters , think it's end of life ,so i will order another .
low fuel pressure  :-\ i fitted a new pump (genuine Bosch) recently
turns out there was a hidden split  in the fuel line from pump to the access plate pipes on the tank ,so fuel was being pumped back into the tank  ::)    I'd already shortened it by 40mm  :-X
had some new fuel ilne and 8mm aluminium tube/pipe ,so used that as the bent sections of fuel line because the original hose was shaped and is NLS  ::)
might see if another model like astra has a shaped fuel line similar available  ;D
it's stopped raining now  :D
Raeturbo
  • South Wales
« Reply #22647 on: 21 August 2021, 22:47:48 »
Try the fuel filter👀🤭
  • Auckland
    • Mazda MPV
« Reply #22648 on: 22 August 2021, 03:11:37 »
Absolutely agree.
There is near zero chance of the body of the master cylinder being in perfect condition given the years in service and time standing idle.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #22649 on: 22 August 2021, 12:06:58 »
It's running with the DUAL filter replaced  :P
if it aint broke ........ :D
