Author Topic: So what have you done to your car today?  (Read 6907714 times)
0 Members and 56 Guests are viewing this topic.
« Reply #22650 on: 22 August 2021, 18:29:11 »
Replaced these with news ones....
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #22651 on: 22 August 2021, 18:36:58 »
Could of got a few more miles out of those surely..😄
« Reply #22652 on: 22 August 2021, 19:32:19 »
Blimey TB, it is about time you reduced your brake service intervals  :o
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #22653 on: 22 August 2021, 19:42:59 »
How???
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #22654 on: 22 August 2021, 20:29:30 »
How bad are the discs if the pads are like that  :o
or did you remove them with a hammer and screwdriver instead of spanners  :D
« Reply #22655 on: 22 August 2021, 21:41:12 »
How???
I would start with the length of time those were fitted for and quarter it.
« Reply #22656 on: 22 August 2021, 22:24:49 »
How???
About 20 minutes,then.🤣
« Reply #22657 on: 22 August 2021, 22:36:06 »
 ;D
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #22658 on: 22 August 2021, 23:02:00 »
Needs to learn to read the road ahead and drive accordingly.  :D
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #22659 on: 22 August 2021, 23:02:43 »
Waste not want not👍
Laying a rubber road.
« Reply #22660 on: 23 August 2021, 20:28:49 »
Discs are fine.  Its the pads have disintegrated.  Its almost as if instead of copper in the pad, they have put iron in, which has rusted.
Pad is about 50% worn, around 5mm of meat left.
Other side was suffering the same, ie, visible corrosion inside the pad causing the pad to break up, but not as extreme.
« Reply #22661 on: 23 August 2021, 20:29:42 »
I do read the road ahead...   ...so I can ascertain the last possible moment to use the brakes.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #22662 on: 23 August 2021, 21:51:50 »
What make are the pads ?
you should have brought ebay ones instead  :D   :-X    :-[    :P
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #22663 on: 23 August 2021, 22:05:36 »
Doubled it's value  :)
just ordered a Bosch S5008 Sealed Calcium battery ,
the biggest that will fit in the tray L278 x W175 x H190mm
780 CCA ,77 Amp hours
5 Years Warranty
« Reply #22664 on: 24 August 2021, 17:19:39 »
Pagid. From Euroshite obviously (seeing as they are now exclusive to the LKQ Group in the UK
Now fitted with some Bosch from egay. Fingers crossed.
