Author Topic: So what have you done to your car today?  (Read 4497703 times)
0 Members and 11 Guests are viewing this topic.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #24030 on: 03 July 2022, 23:48:34 »
Took the omega to the Swansea air show,  five up and performing excellently.  Great show too and can never tire of the excitement of the red arrows they surely must be the very best there is.
Laying a rubber road.
« Reply #24031 on: 04 July 2022, 11:15:57 »
We had them overhead yesterday, twice.  Something to do with the silly Silverstone thing yesterday ;D
« Reply #24032 on: 08 July 2022, 22:43:27 »
Drove it to my Immunisation and Uniform Appointment today.
Got two new holes in each arm and a nice suit only to come out to the car and find the NSR corner sitting low >:(
Fortunately, it pumped back up, so it isn't permanent, but the Airmatic is obviously faulty.
Tested for leaks with soapy water and could not quite decide where the leak is... Not from outside of the valve block, but possibly the NSR airbag or line.  :-\
Fortunately, it doesn't have full Airmatic, just the rears, and also fortunately, Mercedes did offer a couple of models of the Alabama Mumsybus without any Airmatic. So took some digging, and I have managed to locate a pair of rear springs for it.  8)
May also require a couple of bits and bobs to get them fitted, but they locate into exactly the same positions, so will be a permanent fix for significantly less than any individual Airmatic parts.
    • Grandland 1.6 diesel
« Reply #24033 on: 08 July 2022, 23:00:35 »
Opti swears by the air attic suspension. Or is that swears at it?  :-\
Diesel till I die
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #24034 on: 09 July 2022, 00:50:49 »
Presumably also something to either fool the computer into thinking it's still got airmatic, or to code it out of the ECU entirely?
« Reply #24035 on: 09 July 2022, 09:06:54 »
Will start by pulling the fuse to the pump. The sensors can stay as they're probably linked to the xenons...
« Reply #24036 on: 09 July 2022, 10:35:52 »
Are the airbags that expensive that they can't be replaced?  :-\
No alternative to genuine Merc ones?  ???
« Reply #24037 on: 09 July 2022, 11:43:12 »
Genuine are about £400, Chinesey start a £70 a pair... But...
1. The airbag itself may not be the issue.
2. Chinesey things that are 8.5% of the original cost either won't last, won't fit, or both.
Worst case the springs will require £150 in fittings but it will fix the issue. Permanently.
If it isn't the bags, then it's the valve body... Circa £180, or the lines... Not expensive but you have to strip the car to replace them as they run internally. I don't have time to mess around chasing it as I get three days off this week, two next and then I am training until September and need a functioning car. Had I been at Gatwick still I could train it and not worry, but needs must.
  • Auckland
    • Mazda MPV
« Reply #24038 on: 09 July 2022, 11:47:18 »
There are alternatives
https://aerosus.co.uk/mercedes/r-class-w251.html
https://www.arnottindustries.com/products/mercedes-benz-air-suspension/r-class
Also - Back in 2016 AndyB paid to have Mercedes do the job. I don't think he was impressed by the customer service......... https://www.omegaowners.com/forum/index.php?topic=134169.0
« Reply #24039 on: 10 July 2022, 08:18:26 »
Replaced it
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #24040 on: 10 July 2022, 09:29:50 »
Replaced it
which model Tesla did you get  :D
« Reply #24041 on: 10 July 2022, 10:44:15 »
Replaced it
Its her car, and she won't have a milk float :y.  Beyond that, she just knows its a red car ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #24042 on: 10 July 2022, 11:01:15 »
Replaced it
25 BHP extra then being RED  :)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #24043 on: 10 July 2022, 15:30:04 »
P0304 on one of the astra estates  ::)
new plug didn't resolve it ,so fitted a new coil pack ,which did the trick  :)
interestingly .... if you try and buy it on-line to collect from Eurocarshyte they say the discount code doesn't apply to various parts  including the astra coil pack  ::)
as they had 3 in stock ,I just went down and paid and collected in person ,they did apply a discount ,similar to the on-line code .(about 40% off)
so worth checking if you try o order and get no discount  ;) Robbing ****s  >:(
« Reply #24044 on: 10 July 2022, 18:14:13 »
Replaced it
"I think my one is faster than yours, Mr Bond, because mines a red one"
https://www.youtube.com/watch?v=x1Zuo2JtTdY
Probably NWS...
