Bought it a years insurance.
Was going to go monthly and pay the balance in April/May, but the incompetent eedjits claim to have set up the direct debit and taken the first instalment last week. Not according to my bank they haven't, so rather than suddenly finding myself without cover, it seemed to make sense to pay it in full now.
Apparently I will receive a refund of the first payment in a couple of weeks.
If they're that stupid, then I'll have a very nice Chinese ;D
dave the builder
I do my insurances annually  for that reason,
it's 6 points if you find the bank or insurer made a mistake .
and i still check the bank to make sure the payment has gone ,NOT been refunded ,and check ALL the documents
they should give the 6 points to whoever made the mistake , then maybe people would do their job properly  :P
Quote from: dave the builder on 29 December 2022, 16:29:52
Good point well suggested ;)
countrywoman
Managed to get another intake valve from my local engine recon place, £8 cash. Head assembled and refitted, cams timed up and locked with my new timing kit. Alternator, starter and engine mount fitted as well but stuck now as need thermostat, water pump, crank seals and a belt kit. Looks like a remote oil cooler, after an inline thermostat but not found one yet.
Booked it in for an MOT, absolutely no prep work or checks as fooked if I'm rolling around on the drive in this weather.
Wifey came home with a dipped beam bulb out last night. I took it to my local indie this morning and licked his arse because I hadn't booked and he does like an early dart on Saturday. Left it with him for a couple of hours. Got a phone call, went up, he'd done both because that's what should be done, £20.
I don't like admitting that I take a car to a garage just for bulbs, but there just isn't any room in there, and I'm well past working by feel on a wet, windy morning, for the sake of twenty quid.
Diesel till I die
cam.in.head
Quote from: countrywoman on 07 January 2023, 11:18:45
mine has an inline thermostat from a renault 5 i beleive. this just pushes into the top hose. has worked fine for last 5 years !
Quote from: STEMO on 07 January 2023, 11:39:11
Plus he probably had to take the front bumper off to change the bulbs so it would have been silly not to have changed both!  ;D
ronnyd
Quote from: Sir Tigger KC on 07 January 2023, 13:46:03
Remember the good old days when you just opened the bonnet and just reached in as everything was totally accessible
Rangie
In my Range Rover handbook in the bulb section there's a warning in bold Danger of Death !  So I will not be attempting a change of any front bulbs.
dave the builder
Quote from: cam.in.head on 07 January 2023, 11:40:35
I used to fit the Renault 5 stats in the top hose of astra G  1.6 top hoses because some bright spark at Vauxhall hid the stat BEHIND the cambelt  ::) a popular solution  :)
IIRC there was a choice of 82 , 88 amd 92 degree stats
Quote from: Rangie on 07 January 2023, 14:50:23
Never had you pegged as a drama queen...
You simply need to ensure that the headlights cannot switch on before you do anything (auto lights/follow me home lights etc - pulling the fuse is the easiest way) unplug the ballast resistors and leave them sit for a spell before pulling the bulb. You can use the time to remove the lamp assembly from the car.
No different to airbags, and they don't have stickers on them...
Quote from: Doctor Gollum on 07 January 2023, 19:07:02
Have you been watching the Beverley Hillbillies?  ;D
Diesel till I die
Quote from: STEMO on 07 January 2023, 19:22:23
Would it help?
;D
Quote from: Doctor Gollum on 07 January 2023, 19:30:04
Would it help?
;D
It would if you want to talk like a hillbilly  ::)
Diesel till I die
