Raeturbo
🤣 great, I'm just going out in the Evo from Treorchy to Port Talbot taking the Bwlch route🤞🏎️
Laying a rubber road.
Rangie
Got a trade in price for the TDV8 against an SVR just got to sleep on it.
Quote from: Rangie on 23 April 2023, 17:09:14
fabulous lump in the SVR....makes a great noise. :y
Rangie
Quote from: Field Marshal Dr. Opti on 23 April 2023, 17:24:02
Need an insurance quote as well ,I know in London they're refusing to insure them or giving quotes of 3-4 thousand because so many are being stolen, and yes they sound fantastic.
ronnyd
Quote from: Rangie on 23 April 2023, 18:01:12
...as they disappear from off your drive.  ;)
Finally got off my backside and programmed a new key to the Big Black Pussy.  This one has legends on it as well, taking the guesswork out of knowing what button to press on the rare occasions you need to.
YZ250
Washed the dust off it. Drove it to a restaurant for lunch and on the way there I had to drive very slowly due to being behind a driver who had clearly died at the wheel and momentum was the only thing keeping him rolling. Just about to nip by when my snooper eyesight caught sight of Mr Plod lurking in the hedgerow with a Radar, so a special thanks to the dead bloke for keeping my speed down.  ;D
Fitted some new rear disks and pads to the XE. I got my money's worth out of the previous ones. :-X
Quote from: Kevin Wood on 30 April 2023, 23:12:40
How were the calibers?
Migv6 le Frog Fan
A man of your caliber should know its calipers.  :D ;D
Quote from: TheBoy on 01 May 2023, 19:02:27
No problems with them. I suspect one of them might have been a bit sticky because one pad had worn a little more than the rest, but cleaned and lubed the pins and it went back together OK.
Got it into service mode using the pedal trick and it left the calipers alone for the whole afternoon while I was dodging the showers.
Permanently disabled the stop/start BS. Can't believe it's taken me 3 1/2 years to get round to this.
Quote from: Kevin Wood on 02 May 2023, 20:02:47
How was that done then?  :-\
Raeturbo
Well my 3.2 MV6 estate is and gas been running like a watch since James almost reconstructed my entire engine, around 8000 miles since then and getting better each day👍
Quote from: Andy B on 02 May 2023, 20:49:29
I guess it can be coded off. Got it off on my car, unless you drive it in ECO-Pro mode.... which I never do  :)
