Quote from: Field Marshal Dr. Opti on 26 July 2023, 12:45:20
Quote from: Marks DTM Calib on 26 July 2023, 12:41:54
Quote from: Field Marshal Dr. Opti on 26 July 2023, 12:03:08
Quote from: Jimbob on 25 July 2023, 20:46:12
Fixed the Corsa handbrake. Nothing broken in the end. Had just jumped off mounts and seized a bit. Cleaned, greased and reassembled and adjusted and all is well. One happy Harry.
Speaking of the Corsa C.....our car has soaking wet carpets on the driver side floor (behind pedal area is perfectly dry)
Both scuttle drains cleared out the first time it happened.
Where is the water coming from????? :-\
Seal on the bulk head plate where the master cylinder mounts has failed, big job to remove but, had 100% long term success rate by loosening it and forcing sealant in (polyurethane) and re-tightening. Must have done ten of them over the years
Cheers Mark.....I shall do this. :y
If you pull the scuttle cover on the drivers side I bet its full of moss, leaves and dirt, vacuum it all out and give it a real good scrub so the water can flow past and that usually gives a quick improvement
Quote from: Marks DTM Calib on 26 July 2023, 14:09:22
Quote from: Jimbob on 26 July 2023, 12:55:55
Passenger side leak on this one!  only seems to be when facing uphill in the rain, also checked the drains etc last night
Electrical box cover seal:
https://www.ebay.co.uk/itm/175570275415?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1fffH-2jdTNubT8xx-cADGg63&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=175570275415&targetid=1816181028659&device=c&mktype=pla&googleloc=1006886&poi=&campaignid=19090194174&mkgroupid=147009364227&rlsatarget=pla-1816181028659&abcId=9303860&merchantid=7272254&gclid=Cj0KCQjwiIOmBhDjARIsAP6YhSVproEFPT6qB3HwpFjiITDJZXBdQSGH1fA82-Wlfmc91cedGcc9MC4aAlgbEALw_wcB
Shall have a look
Finally got a bastard bracket back on mine (that I didn't need to take off, grrr).  And it starts.
Just hearing that somebody has idiotted hers, FFS
Looks to be just the bumper.  It looks creased/cracked, so suspect it'll be a new bumper.
dave the builder
Quote from: TheBoy on 26 July 2023, 16:45:46
excellent progress  :) always a nice feeling when it starts ,after you had it in bits , well done  :y
Quote from: TheBoy on 26 July 2023, 17:25:01
Oh dear ,what a nightmare  :(
Just what you need.
Raeturbo
You're doing well buy a lottery ticket ;)
Laying a rubber road.
GastronomicKleptomaniac
Bit of underseal and a clean underneath Ezekiel. It's done about 1000 miles this year and isn't looking too shabby.
Then fiddled with the 406 for a bit, in anticipation of a mild remap and a bit of cosmetics.
Any suggestion I was putting off looking at the Mk2 Golf project is downright slanderous, but as it happens I've got a bit more done on that too.
I am CAKED in filth.
Quote from: Marks DTM Calib on 26 July 2023, 14:17:37
Will do. :y
Done about 15 miles on local roads this morning.
Keep getting (false) coolant level warnings, and getting quite a lot of smoke from the other bank once its had a drive. Hmmmm....
Rangie
Booked it in ( Range Rover) for its annual service & MOT on the 14th of August.
Begun retrofitting a reversing camera. Managed to acquire both the boot lid and main ECU to fuse box/dash display for a fair price so figured why not... ::)
Boot lid all done and back together, just waiting for the other loom to arrive so I can dismantle the rest of the car.
Quote from: Doctor Gollum on 01 August 2023, 21:22:29
Begun retrofitting a reversing camera. Managed to acquire the camera, ECU and both the boot lid and main ECU to fuse box/dash display looms, brand new Mercedes, for a fair price so figured why not... ::)
Fixed to make sense
Reversing camera all plumbed in except the programming to activate it and a bracket to secure the ECU.
Booked my desirable and very valuable Vauxhall in to have an exhaust bracket welded on for the MOT next month.
Are the aluminium heat shields required for the MOT?.
