Quote from: dave the builder on 21 November 2024, 10:11:03
Tuesday I took one astra H 1.6 estate for MOT .it passed ,no advisories  :)
then took my omega 2.6 for MOT , it passed ,no advisories  :)
then late afternoon I took the Astra G 1.4 for MOT ,passed, no advisories  :)
I've been very busy recently ,so didn't prep the cars as much as i would normally .
omega has a crack in the plastic side tank of the rad by battery ,weeps slightly when hot .
I've got a new rad from partsinmotion ,just need to find time to fit it  ::)
Wow, good results!
Well done, even if you did nothing ;D
Took the toy to work today, a few interesting moments!
Quote from: Marks DTM Calib on 22 November 2024, 11:47:44
I ended up having to give an armful of opposite lock earlier.  It was only one armful, as I was supping a drink with the other arm at the time ;D
Rangie
Took the RRS & a large trailer over to Cambridgeshire to collect a lot of stone for a barn conversion we're starting ( son in law the builder)
Just amazed how effortlessly the TDV8 tows whatever you hitch up to it.
Quote from: TheBoy on 23 November 2024, 18:07:24
It was a new experience to change lane, in an overtake manoeuvre, by entering the outer lane rear first (neatly followed by the front), the guy in the van behind was killing himself laughing
Quote from: Marks DTM Calib on 25 November 2024, 11:56:55
Yes, not tried that one before.
I've come off a roundabout backwards before, fortunately hardly anyone around to laugh ;D
Migv6 le Frog Fan
Seals for Stat and transfer pipe arrived this afternoon. Fitted the stat and transfer pipe, then had a half hearted attempt at fitting the bastid bolt.
Decided to call it a day and have a proper go at it tomorrow.  ::)
Quote from: Migv6 le Frog Fan on 26 November 2024, 21:02:40
Gently does it, old fella  ;D
Diesel till I die
Migv6 le Frog Fan
Finally got around to reflashing the rear door modules to get the rear windows functioning again... they've not worked since I first looked at the car.
All good except the drivers side one worked backwards from both switches.
Did some digging and found nothing new wrong with the motor or switches, so had a headscratch and unbolted the motor from the drive assembly and rotated it 180° effectively reversing the poles.
All back together and functioning the right way around again.
Also fitted a replacement passenger door mirror glass which cleared a persistent fault code for a failed heater element.
Now down to just three fault codes... Dynamic Seat pump dead, Night Vision not calibrated and Boot Lid closing incorrect VIN.
Booked in for the trans control module tomorrow so hopefully that'll be the gearbox back to working...
My windows open properly, on demand.
Closing, well, it's a JLR product, so that's less predictable....
;D
Quote from: TheBoy on 27 November 2024, 18:29:44
;D
Your seat pump works rather well, too  ;D
Diesel till I die
Migv6 le Frog Fan
Got the Bastid bolt back in, top hose fitted - that did put up a bit of a fight.
Pressure tested the system and when it got to around 0.5 bar coolant pissed out from under the stat.  :'( :'( >:(
Its just had a new seal so god knows why its leaking.  ???
Got to  take it all apart for the third time, try and work out what the problem is, and then do it all again.
Maybe buy a new Stat housing in case this one has warped ?  :-\
YZ250
Quote from: Migv6 le Frog Fan on 28 November 2024, 18:06:24
Is it possible that the stat housing has a hairline crack in it.  :-\
