Quote from: aaronjb on 31 July 2012, 13:59:14
Quote from: taxi al on 30 July 2012, 17:37:53
Mmm sport badges are, well, badges ::) reminds me of the late 90's when everyone wanted red Tdi badges on their 90bhp 1.9 tdis ;D
It's funny, but this M sport badge came with the M engine, M suspension, M .. etc ;) E46 M3.
That's alright then  :y ...at least it's not an Audi  ::). I know someone who had an E36 1.6 coupe, with M wheels,  body kit and interior. Quite a smart look easily destroyed by simply starting the thing ;D
Quote from: taxi al on 31 July 2012, 15:39:05
;D ;D Nah, I'd rather have a M3 that looked like a 316 ;) I got passed by what looked like a standard 325 the other day - he went past like I was stood still so I googled the badge on the back ('357ci') - turns out it's an E46 with an LS1 swap ;D
A cracking car. :y
Manual Elite V6
When I got home from work I changed my front ARB links and bushes, rear subframe bushes and sorted out a blowing exhaust joint on my mates polo.
Car is now much firmer at the back and much more quiet when driving.
1992 Cavalier GSi
2007 Astra Sri+ CDTi 150
bored bigyin54
fixed my ashtray thanks to rob g and fixed a leak in the wash wipe pump :y :y
Victor Meldrew
Flushed and changed the coolant, then went and had my pocket felt by George Osborne for another 6 months Road Tax. Thieving git!
"A normal man in a world full of idiots"
natsdad
Over the last 3 weeks I have done the following to my 03 plate Elite estate.New bottom arms and bushes,Drop links,Brake pads front and rear,Engine service.This is on a car with full dealer service.Ive owned this particular Omega 8 months.What next?.
Quote from: natsdad on 03 August 2012, 10:26:34
Heater Bypass Valve,  Cam Cover Gaskets,  Rear Shocks, Cambelt and Water Pump :-\ oh and nearly forgot, Indicator stalk  ::)
Don't worry though, it's actually only a handfull of things that go wrong, and once done once, you know what to expect next time :y Which is precisely why we're all here :y
You've been busy because of your cars dealer servicing rather than in spite of it :-\ small consolation, I know, but you are getting there :y
p.s. Did anyone mention coil packs and crankshaft sensors :-X Hello and welcome btw :y
Is it still running better following our tinkering, Al?
For the most part it is still behaving itself thank-you  :y I've a new breather bridge and that pipe on order, and will replace the rubber connections on the vac hoses just to rule them out :y next step after that will be a brand new loom I think. Does still have the odd hissy fit, but they do seem to be milder... need to replace the EML light though as it's finally gone out  8) permanently :'(
What's the internal diameter required for the Vac connections :-\
ndmv6
well,finally given up  with my omega and traded it in...20mpg around town and 32 mpg on a run is no good for me these days...sad to see it go,but it was clapped out... :)
Took mine for a late (by about a week) MOT
It passed!!  :y :y :y :y No (written) advisories, but could do with a couple of rear tyres ( ;)) but I already knew that.  ::) ::)
omegod
Brake fluid changed and trying to muster up the will to check and top up the ATF
twiglet
Quote from: Andy B on 03 August 2012, 19:28:02
Good work Andy, if a little late!  ;)
I'm glad you posted this though, because it jogged me to go and check the MOT dates on mine.  I thought they were due Sept/Oct, but it turns out I've got 4 due this month!!  ::)
