Quote from: Elite Pete on 09 January 2013, 07:18:21
Quote from: Albitz on 09 January 2013, 00:20:14
Quote from: Kevin Wood on 08 January 2013, 22:28:56
Quote from: cem on 08 January 2013, 22:13:00
Quote from: Kevin Wood on 08 January 2013, 22:03:22
New battery arrived for the Westfield. :D
I had a suspicion that mail ordering it was a bad idea, though >:( Thank you Useless Pratt Service. One of your retards obviously read the "Fragile" sticker (one of the bright ones, then) and it was a red rag to a bull. One cardboard box full of battery acid, and a battery missing a corner. :'(
???  joys of virtual shopping... I had bad experiences with batteries.. I never buy a battery before the seller checks every point in my car.. so they cant claim the car to be faulty
Problem is, the battery is tiny, from a Renault 4 or something, and going obsolete. ;D Having trouble finding a motor factors who stock it. ::)
Might a biggish bike battery do the job Kevin ?
An MX5 battery is very small :y
so you can use them interchangebly with mobile batteries ;D ;D ;D :y
GastronomicKleptomaniac
Finally finished the thermostat, it's been a half-hour at a time job when I've been getting in from work, so three lots of buggering about and it's finally done. :y
Sam Burton
Quote from: VXL V6 on 08 January 2013, 19:52:24
Chucked Pedders bushes in the boot of the V6 so they can get to know the wishbones, wishbone front and rear polly bushes, B4 shocks, spring seats and various other new bits that will all be fitted in the 2013 Epic Project called 'either Fix it or Flog it or Set fire to it'  ;D
Problem is Project 'Cambelt Kit and Exhaust' is slightly more important at the moment.
Next problem is Project 'DTi inlet clean' is far more urgent than all of them!
So... yep i've done absolutely nothing on my cars today  :D
I Know that feeling !!!!
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
Serviced Joshs bus today :y had to change the 246 coilpack as it was caked in a soggy orange mush :-\
Suspect the scuttle for that... Swapped the cam sensor with mine, but EML still on, but haven't driven it since ::)
Guinney1971
Put it up for sale!   ;D
Claire & Phill
Renault Grand Scenic 'Maxim' 1.9dCi 120
Struggled to get it above 40mph today  >:(
Finished installing rear blind & shelf.Put it all back together and the blind struggles to pop out of its slot.Give it a helping hand to come out of the shelf and it goes halfway up the rear window and stops.It worked perfectly in the car it came out of. :(
Turned the radio up even more to drown out the clatter/clonk/tapping  ::) At least pedestrians have a pre warning im 50ft behind them  :(
Quote from: Albitz on 09 January 2013, 18:44:30
did you lube it first? The blind I mean ..? Well, the sliders in the top runners actually.
some oil in proper place will solve..
v6man54deg              Geffd
Noticed i was loosing a little bit of coolant plus bit of a squeak on engine on start up - noticed it was the water pump - got a bargain brand new GM pump from the bay for £22 delivered!  (think they have more on there) last time i bought one from vauxhall with VM discount it was over £50! anyway on removal the bearings were knackered must have been the original pump which lasted 87k - belt was changed at 60k on checking the valve timing 1-3-5 bank was just slightly out - belt tension was incorrectly set (too much tension) but still as it has done 27k since belt change not too far out - have seen a lot worse than that
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
Stallion
Changed front suspension struts, steering idler arm and anti roll bar links!! That was a handful.. Quick question changing the steering idler arm, does that ruin the tracking?  :y
Quote from: Stallion on 11 January 2013, 16:18:06
No
