Discovered I was running on slicks....
....still, enough traction available, even in this cold, wet weather, so they'll be replaced with normal summer tyres :P
Quote from: TheBoy on 29 December 2013, 13:59:04
Hopefully the new ones will have some air in them ::)
Quote from: ex taxi al on 29 December 2013, 14:07:21
Pressures are correct. I tend to run 32 at front and 30 at rear. Even so, the wear pattern on rears implies overinflation.
Following on from the Christmas Eve puddle encounter, today I have been doing mostly this...
Took forever to set, but sanded down to 800grit ready for priming. Had to strip as much as I did as the paint had cracked in chunks over a third of the length :o
Split was only 6" or so ::)
I think you'll find 800grit way too fine for primer.
Actually, it's probably a bit much to be sanding the primer with 800
chrisgixer
Quote from: TheBoy on 29 December 2013, 14:25:04
So which tyres are these? The F1's or the sport maxx?
Shall I bump the oof tyre thread?
Quote from: Nick W on 29 December 2013, 20:22:25
The initial shaping was done with 40 grit, so still pretty rough, but no longer fluffy...
chrisgixer
Quote from: TheBoy on 29 December 2013, 21:06:42
SC5s. Good fooking riddance
Thought you where saving those for the airfield do. ;D
...of all the things to survive the fire. ::)
Johnny English
Transmission main shaft oil seal swap. Sorted. :y
C20NE - X25XE
I seem to be missing a car. I'll ask Mrs TB when I get out of the bath if she knows where it is.
It wasn't that windy last night, was it?
Beer induced befuddlement per chance ::)
chrisgixer
chrisgixer
Quote from: chrisgixer on 29 December 2013, 21:16:20
...and what to fit next, btw?
