Quote from: chrisgixer on 23 May 2014, 22:45:27
Quote from: tunnie on 23 May 2014, 22:41:18
Tanked the 2.2 up on LPG, done the mpg figures, slap in face moment how damn cheap my 2.2 is to run.
24mpg on gas, at 0.69p litre. ~12.5p a mile running cost. I never get less than 24 over a tank, unless 100% city work.
To get same cost per mile from a diesel @ £1.34 ltr, I would need to average 47mpg. So to average 47 over a tank from diesel would be tough, as big chunk of my commute is stop start.
Add in bloody cheap servicing, even if I fix aircon (condensor+compressor), replace the clutch and HG, it's still cheap to run  ;D
Yeah but who tf wants   Er .... to be constantly late all the time. ::) ;D
It's knowing the back routes, not the horses you have under the bonnet. :)
Actually this has compounded for me to not LPG the 3.2, I think I could get 20 maybe 21mpg tops on LPG, more like 19 I think though, given a lot of my runs is stop start.
20mpg on gas, is around 37mpg in diesel costs, so yourself/TB with 16mpg on gas, gets around 30mpg cost on the wallet for diesel? Might as well get a 3.0d which does more to the gallon and is quicker  :D
SIR Philbutt
Could not have put it any better myself  8) :y although my 12 month rolling calculated average MPG (LPG & Petol) is only 20. My Pence Per Litre is only 82p though. Love that when i see it
How are you getting 24 ?
chrisgixer
Quote from: SIR Philbutt on 24 May 2014, 00:18:12
By arriving late. A lot ;D
Honestly Tunnie, get rid of the poxy thing .  Or at least look after it. One or the other ::)
Quote from: tunnie on 23 May 2014, 22:51:42
20mpg on gas, is around 37mpg in diesel costs, so yourself/TB with 16mpg on gas, gets around 30mpg cost on the wallet for diesel? Might as well get a 3.0d which does more to the gallon and is quicker smells and sounds like a skeleton masturbating in a biscuit tin  :D
Fixed that for you. :y
plym ian
Quote from: Kevin Wood on 24 May 2014, 00:35:58
Nice one ;D ;D
Yours an auto?
I just drive normally, MrsT tells me often to slow down  :o
I have seen 28 average over a tank, Wales and back. Cruise set at 80 :)
Quote from: chrisgixer on 24 May 2014, 00:32:44
Everything I look at is vastly more expensive to run.
What else averages 50mpg and is cheap as chips to fix and is comfy and silent on a cruise?
chrisgixer
Quote from: tunnie on 24 May 2014, 10:11:45
Fair do's. But at least clean it, no?  If its that important to you.
Obviously anything that replaces it will cost money of some sort. So why buy the 3.2 and not use it?
Me finks Tunnie is confuddled. :-\
joff
Well I now have a set of refurbed wishbones in the garage with poly fronts and Febi Bilstein rears with Lemforder ball joints all mounted on a pair of Vauxhall wishbones off the MV6 and if this rain stops for another 30 mins I am going to fit them on the DTi estate and check the steering idler again. :o :o
Quote from: chrisgixer on 24 May 2014, 10:19:33
2.2 did get a clean and a hoover, looking good again  :y
3.2 is the 'spare' and for MrsT and her needs  :)
Tbh, the cost and it's unbelievable bodywork was reason to buy.
Stemo
Quote from: tunnie on 24 May 2014, 13:27:32
Mrs T?
joff
Quote from: joff on 24 May 2014, 13:06:29
One side done, just over the hour for one out and one in. Drivers side tomorrow :D
Four new tyres on Mrs VXL's Alhambra. Thought we'd give Accelera Alpha's a try, obviously being an MPV it has to have reinforced (XL) ones - was impressed with the rim protection on them, mind you, it's a little too late for the kerbed alloys  ::)
