Quote from: Taxi Al on 19 May 2014, 20:33:26
Quote from: chrisgixer on 19 May 2014, 20:30:54
Who said anything about the 2.2?
He needs an estate and can't bring himself to fit the lpg kit to a desmond estate, as that would mean getting rid of the desmond saloon... not helped by liking the 3.2 ::)
That desmond saloon needs a conversation with a bin lorry to force a decision :-X
As usual, spot on.  :y
The key problem is I cannot let go of my trusty 2.2, I would have to have my hand forced. Either by it having a physical reshape or combination of clutch & hg going.
Quote from: tunnie on 19 May 2014, 20:50:40
Oooo don't tempt fate Tunnie!  :o  ::)  ;D
Quote from: Sir Tigger on 19 May 2014, 21:32:25
I do get clutch judder/slip, 2nd gear low speed judder then clears. 171K on same clutch and original HG on a 4 pot. Can't help but feel I'm borrowed time  :(
Quote from: tunnie on 19 May 2014, 21:48:03
Easy fixes though, and probably worth it if the bodywork is good.  :y
Quote from: Sir Tigger on 19 May 2014, 22:00:17
That's the problem. Body work is solid, exhaust good, recent wishbones new belt kit. Cheap repairs, no reason to chop it in!
Quote from: tunnie on 19 May 2014, 22:20:53
You know it makes sense!  :y
chrisgixer
Fit an upright toroidal in the spare wheel well. They have their draw backs, but I doubt a certain Tunnie will notice tbh.
Quote from: chrisgixer on 20 May 2014, 01:43:49
Range is the problem, not many LPG filling sites that a nice and local. One on my commute which is good, but nothing around here.  :(
Quote from: tunnie on 20 May 2014, 09:15:49
We can rustle up a plasma cutter and a couple of welders.. We'll convert your saloon into an estate. There you go.. problem solved. :y
Yup, definitely no lpg within two minutes of Camberley ::)
Fleet service station on the A3013/327 junction
Fleet services both sides
Dedicated place in Farnborough
Cobham Sainsburys
A couple of places in Bracknell
To name but a few, not to mention the rest of the world ::)
Quote from: Taxi Al on 20 May 2014, 10:24:14
Cobham Sainsburys
You have seen LPG Motorway prices? Might as well run the Elite  ::)
Bracknell, no reason to go there, it's not on a commute. Long way to go just to stick some fuel in, same with the rest, either way, range is a problem as I keep saying  ::)
Where's the place in Farnborough, out of interest?
The A3013/A327 one is the cheapest in the area and where I normally fill up. There's one on the A31 at Farnham too. More expensive - normally 71-73p but a very fast pump, especially if you have a 4 hole tank.
Quote from: tunnie on 20 May 2014, 10:54:38
Fleet services are very reasonable, IMHO. Currently 69.9 IIRC.
I'll add I would covert the 3.2, if I was using it or commuting.  :y
At the moment, I need to the boot and spare tyre  :)
Quote from: Kevin Wood on 20 May 2014, 10:56:17
Surprises me, most times I've been in M4 LPG services it's not far off 80p  :o
