biggriffin
Quote from: Sir Tigger on 14 September 2014, 00:53:22
Quote from: chrisgixer on 13 September 2014, 21:47:53
Quote from: Sir Tigger on 13 September 2014, 19:05:00
Wishbones!  :y  Never again!!  ::)  ;D
Forgot the new front brakepads as well.  :y
Never again until the next time? In a "I'm never drinking again" stylee,given Tiggers addiction to anything not gm/lemforder/mayle/anyotherknownmake....?
I'll 'ave you know that my lucky Omega has recently received Lemforder topmounts and bearings, GM camcover gaskets, KYB rear shocks, GM front pads, Febi drop links, GM HBV, approx 12 litres of 'Genuine' GM 10w40 and a pair of ATP wishbones direct from the Fatherland as recommended by that Taxi fella who dosn't get on with folk!  :P  :y
Blimey had a lottery win.
Hoof'land storeman.
Quote from: biggriffin on 14 September 2014, 09:11:33
Ha no such luck!  ;D If that had been the case, it would have all been Gm parts direct from the local stealer.  ::)   :-\
Well actually probably not, because what I don't do is blindly fit Vx parts just because it's Vx/GM.  ::)
Vicar
Just been checking under the bonnet of mine,, I need a pollen filter now because the one in place right now, looks like it's never been out since it left the factory.  :o Are there loads about or is it gonna be a dealer job?
Quote from: Vicar on 14 September 2014, 10:39:27
PFL are easy to source. FL needs carbonised ones, which are more expensive, and less common in aftermarket. Tradeclub prices are around £5 and £15 respectively
Vicar
Quote from: TheBoy on 14 September 2014, 10:46:58
cheers for that. It is a pfl so shall go look. Never seen a filter as bad as this one. At least it's dry down there. I also spotted the battery clamp and bolt are missing so need to source these also along with dipstick. Trip to scrappie I think.
That's been really well maintained then... ::)
Washed two of them....
Conclusion, Star Silver III Z157 hides the dirt better than Black Z20R  ;D
X30XE
Replaced torn vacuum hose between T piece and multi-ram.
Smiled at the much improved torque curve.  :)
Omegatitis : [in remission]
Quote from: TheBoy on 15 September 2014, 18:36:18
Made the Bullet understeer. Cock.
On the upside, the oversteer issue is resolved...
chrisgixer
Surely you haven't fitted anything other than rt?
Quote from: chrisgixer on 15 September 2014, 18:37:33
The fronts aren't due replacement for a while...  ...although the way I'm eating Eagle F1s, that may not be too long  >:(
chrisgixer
Oh he's talking riddles again. Whatever.... ;D :P
Quote from: chrisgixer on 15 September 2014, 18:41:57
The RTs went on the back, just to clarify for the Reading contingent....
