GastronomicKleptomaniac
Pair of new rear dampers on mine, since one of them decided to deconstruct itself and drop one of the bump stops God knows where... Nice simple job, under an hour including tea breaks and untangling one's headphones. And chasing the woofer up the street after she saw the perfect chance to escape as I jacked the car up...
Quote from: Doesn't play well with others... on 18 September 2014, 22:49:28
I had no expectations before driving it (having never driven so much as a milk float), and left very, very impressed.
A doddle to drive in traffic, and on the motorway, accelerating into a gap is so quick it needs alot of care, but no wallowing, little roll and just enough road noise to remind you that you're actually in a car... wasn't as surreal as I thought it might be. And certainly alot more agile than a 2.1 ton car deserves to be ::)
£1300 pm is alot on the face of it, but I currently use about £1000 of diesel each month... if the lease rates can get below a grand (broadly the cost of buying and running an lpg Zafira) then it is worthy of serious consideration...
But is there enough space in it (and boot)?
Quote from: TheBoy on 20 September 2014, 13:33:06
Room in the boot for two rear facing seats... And room in the front for 150 litres of luggage where the engine used to live... Boot is good for at least four suitcases, and being a hatchback it doesn't suffer from saloon style height restrictions, with even more storage space beneath the boot flor where the fuel tank used to be... There's a video of a Norwegian road test, which I shall rummage up later, that shows just how much stuff you can fit in it :y
Slapped some new rear pads in TBE. I thought the best way to bed them in was to do a 1 point turn in Brakkers High Street ::)
However, with TC switched off, it doesn't bed them in much ;D
Here do... http://www.youtube.com/watch?v=XZ5PqPeOPT0&feature=youtube_gdata_player :y
Mr.OmegaMan
Took it for a drive some 150 miles seen as it was a nice day  :y
4x4
Quote from: TheBoy on 21 September 2014, 20:56:16
I shall look for the tyre marks tuesday  ;D
Finished plumbing in the CCRT2008, which now works a treat 8) and replaced a busted mirror casing with an unbusted one and fitted a replacement B post trim as one was scratched when i tried to clean the sap off it ::)
Sealed up scuttle on the 2.6 again, or to be more precise, sealed up the bit of scuttle I didn't seal up last time.  ;D
Diamond Black Geezer
(This on the SORN V6 up the drive ready for her mini-restoration and return to Britain's roads)
Had a new flange welded on the rusty exhaust cat, as I greatly assisted by standing over him  :y
Second hand - but decent - exhaust given coat of paint
Ready for fitting tonight/tomorrow, we hope.
Picked up a wheel after yet another puncture.
Reset the codes on TBE after she said the EML was on. She needs to rag it more.
Quote from: TheBoy on 24 September 2014, 18:41:59
Driving the 3.2 gently does rather put that light on before you can say "0420,0430" ;D
chrisgixer
Quote from: Doesn't play well with others... on 24 September 2014, 20:37:15
Gota keep those cats hot. Yeeeeee haaaaaaa.....
.....not sure that will stand up in court mind. ;D
