4x4
Lol i dont need to have a button  ;D
Means something expensive to go wrong if button operated
Frontera shall be ready for going off road ready for yarwell on oct 5th  :y
biggriffin
Quote from: 4x4 on 06 September 2014, 15:27:59
Gone from this
To this  ;D
3" lift at rear and 2" lift at front  ;D
Just need some yellow shock absorbers,and a 50ton winch, proper 4x4 then :D
Hoof'land storeman.
4x4
Lol,winch will be next year,got brakes,snorkel,mot and tax to do within the next 2 months ;D
How does that affect the handling on the road?  ???
My mate had a raised up Disco once and it was awful to drive.  He ended up putting the stock springs back.  ::)
4x4
It still drives ok,i used 3" spacers on rear and raised the front on the torsion bars.
Quote from: 4x4 on 06 September 2014, 20:51:32
I think it looks wicked man  :) Looked really good parked on the green outside my house , ready for tin tent towing  :D
4x4
Changed starter motor,  :(
So much for an easy job,think vx designers were on some very bad drugs when doing the frontera,2 hrs to get everything out the way,10 mins to remove starter,5 to refit it,put everything back together,turns over great,bur the bloody thing wouldnt fire,double checked everything and found fault on loom,it started,great,took it out for test drive,run like shit,engine light on,lpg run shit,decided to strip loom down 10 mins in to it found the problem,some idiot had not tightened a bolt up which holds several earths ,tightened it up,put it back together and now runs perfect,i will not be doing that again  >:(
the alarming man
i think Vx designers are on  drugs permanently (prerequisite of applying for the job) bunch of self-abusers
Pumped some oxygen into the fronts and found out how to remove the front mud flaps without having a hernia  ::)
Took the Omega for an MOT.
Another years ticket granted.
I'd forgotten that it had a sidelight bulb out .. but since they charged me all of £2 to change it, I'm not going to argue ;D
Advisory on drop link boots worn and minor play in the steering idler.. both things I knew about though so no surprises there either.
Fitted new radiator (pattern one that is designed for 2.6/3.2's  :y)
